Aller au contenu principal
Canon PowerShot G11 Front Cover Replacement
Ce dont vous avez besoin
  1. Canon PowerShot G11 Front Cover Replacement, Rear Cover: étape 1, image 1 de 1
    • Remove the three screws on the bottom of the camera using the 00 sized phillips head screw driver.
  2. Canon PowerShot G11 Front Cover Replacement: étape 2, image 1 de 1
    • Remove the four screws on the left side of the camera.
  3. Canon PowerShot G11 Front Cover Replacement: étape 3, image 1 de 1
    • Remove the screw on the right side of the camera.
  4. Canon PowerShot G11 Front Cover Replacement: étape 4, image 1 de 1
    • Open up the HDMI port on the right side of the camera. Then remove the screw in the HDMI port.
  5. Canon PowerShot G11 Front Cover Replacement: étape 5, image 1 de 1
    • Remove the screw to the right of the view finder on the rear of the camera.
  6. Canon PowerShot G11 Front Cover Replacement: étape 6, image 1 de 1
    • Use the spudger to crack open the case.
  7. Canon PowerShot G11 Front Cover Replacement: étape 7, image 1 de 1
    Outil utilisé dans cette étape :
    • The rear case is still attached to the camera with a ribbon cable. The socket has a flip up lid that must be flipped up before the cable can be removed. Use the tweezers to flip the cable attachment up.
  8. Canon PowerShot G11 Front Cover Replacement: étape 8, image 1 de 1
    • The rear cover is now unattached from the camera.
  9. Canon PowerShot G11 Front Cover Replacement, Front Cover: étape 9, image 1 de 2 Canon PowerShot G11 Front Cover Replacement, Front Cover: étape 9, image 2 de 2
    • Push the button on the bottom right of the camera and then remove the plastic surrounding the lens.
  10. Canon PowerShot G11 Front Cover Replacement: étape 10, image 1 de 1
    • Use the spudger to pop off front case.
  11. Canon PowerShot G11 Front Cover Replacement: étape 11, image 1 de 1
    • Pull the loosened cover off and you are finished.
3 autres ont terminé cette réparation.
Dustin Brinegar
Membre depuis le 01/21/15
688 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team 5-6, Brown Winter 2015 Membre de l'équipe USF Tampa, Team 5-6, Brown Winter 2015
USFT-BROWN-W15S5G6
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 7
Total : 2,483
