Aller au contenu principal
Canon PowerShot G3 Speaker Replacement
Ce dont vous avez besoin
  1. Canon PowerShot G3 Speaker Replacement, Speaker: étape 1, image 1 de 1
    • Start to remove the screws around the camera: from the front, back, sides, and bottom.
  2. Canon PowerShot G3 Speaker Replacement: étape 2, image 1 de 1
    • Once the screws are removed, remove the back panel. The panel should be able to be removed by hand.
  3. Canon PowerShot G3 Speaker Replacement: étape 3, image 1 de 1
    • Next remove the front and right side panels (the left is attached to the front panel).
  4. Canon PowerShot G3 Speaker Replacement: étape 4, image 1 de 1
    • Finally, remove the top panel as shown.
  5. Canon PowerShot G3 Speaker Replacement: étape 5, image 1 de 2 Canon PowerShot G3 Speaker Replacement: étape 5, image 2 de 2
    • The front of the camera should now resemble the picture shown. (Image 1)
    • Remove the capacitor/speaker housing using your finger nail or other thin object to lift it up around the edges. (Image 2)
  6. Canon PowerShot G3 Speaker Replacement: étape 6, image 1 de 1
    • To remove the circuit ribbon (brown strip) pull it out of the plastic piece it is connected to.
  7. Canon PowerShot G3 Speaker Replacement: étape 7, image 1 de 1
    • You should now be able to see how the capacitor/speaker housing slides out of the frame.
  8. Canon PowerShot G3 Speaker Replacement: étape 8, image 1 de 2 Canon PowerShot G3 Speaker Replacement: étape 8, image 2 de 2
    • Disconnect the speaker wires from the camera, then use a small flat head screw driver to lift the speaker out of its housing.
    • Order a new speaker from the manufacturer or take it to a local electronics store to see if they have one.
Ryan Riales
Membre depuis le 10/22/15
201 Réputation
2 tutoriels rédigés
Équipe
University of Memphis, Team 3-2, Kim Fall 2015 Membre de l'équipe University of Memphis, Team 3-2, Kim Fall 2015
UM-KIM-F15S3G2
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 11
Total : 256
