Aller au contenu principal
Canon PowerShot G7X Dial Replacement
McKenzie Devlin
McKenzie Devlin et 4 autres contributeurs
Dernière mise à jour le June 15, 2018
7 - 10 minutes
Modérée
In this guide, we will be showing you how to remove the flash dial in order to replace it.
Ce dont vous avez besoin
Outils
  • Spudger
    Spudger
  • Phillips #000 Screwdriver
  1. Canon PowerShot G7X Dial Replacement, Dial: étape 1, image 1 de 1
    • Remove the five 2mm Phillips #000 screws that are under the screen of the camera.
  2. Canon PowerShot G7X Dial Replacement: étape 2, image 1 de 1
    • Remove the two 3mm Phillips #000 screws under the AV-out digital flap.
    • Remove the two 3 mm Phillips #000 screws from the side of the camera.
  3. Canon PowerShot G7X Dial Replacement: étape 3, image 1 de 1
    • Remove the two 3 mm Phillips #000 screws on the side of camera with the flash toggle.
  4. Canon PowerShot G7X Dial Replacement: étape 4, image 1 de 1
    • Remove the four 4 mm Phillips #000 screws from the plate on the bottom of the camera.
  5. Canon PowerShot G7X Dial Replacement: étape 5, image 1 de 1
    • Remove the back plate.
  6. Canon PowerShot G7X Dial Replacement: étape 6, image 1 de 1
    • Remove the three 3 mm Phillips #000 screws around the dial.
  7. Canon PowerShot G7X Dial Replacement: étape 7, image 1 de 2 Canon PowerShot G7X Dial Replacement: étape 7, image 2 de 2
    • Using the nylon spudger, gently lift the ZIF tab.
    • Disconnect the ribbon cable that connects the dial to the motherboard.
    • Remove the dial from the device.
McKenzie Devlin
Membre depuis le 04/09/18
195 Réputation
1 tutoriel rédigé
Un commentaire
Good guide. If you need to repair the jog dial, check this video for an excellent guide: https://www.youtube.com/watch?v=amuCb5ko...
jnbruin - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 13
Total : 598
