Aller au contenu principal
Canon PowerShot S100 Outer Case Replacement
Ce dont vous avez besoin
  1. Canon PowerShot S100 Outer Case Replacement, Outer Case: étape 1, image 1 de 3 Canon PowerShot S100 Outer Case Replacement, Outer Case: étape 1, image 2 de 3 Canon PowerShot S100 Outer Case Replacement, Outer Case: étape 1, image 3 de 3
    • Remove the 2 screws (3.2mm, Phillips #00) found on the bottom side of the camera.
    • Remove the 2 screws (3.2mm, Phillips #00) found on the side of the camera.
    • Remove the 2 screws (3.2mm, Phillips #00) found on the side of the camera where the terminals are.
    • Open the flap revealing the cable inputs and remove the final screw (3.8mm, Phillips #00) found inside.
  2. Canon PowerShot S100 Outer Case Replacement: étape 2, image 1 de 1
    • Turn the camera so that the LCD screen is facing you.
    • Remove the back panel by pulling it off of the camera.
  3. Canon PowerShot S100 Outer Case Replacement: étape 3, image 1 de 3 Canon PowerShot S100 Outer Case Replacement: étape 3, image 2 de 3 Canon PowerShot S100 Outer Case Replacement: étape 3, image 3 de 3
    Outil utilisé dans cette étape :
    • Turn the camera so that the lens is facing you.
    • Do not pull the front panel off without removing the ribbon cable first.
    • Slowly lift the front panel from the camera.
    • The ribbon cable is connecting the front panel to the camera. Using the tweezers, gently pull the ribbon cable out of its socket.
    • A spudger may also be used to remove the ribbon cable.
    • Remove the rubber guard that rests on top of the lens.
Ricky
Membre depuis le 02/23/15
968 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team 1-4, Leahy Winter 2015 Membre de l'équipe USF Tampa, Team 1-4, Leahy Winter 2015
USFT-LEAHY-W15S1G4
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 2
30 derniers jours : 6
Total : 1,205
