Aller au contenu principal
Canon PowerShot S400 Shutter Button Assembly Replacement
Ce dont vous avez besoin
  1. Canon PowerShot S400 Shutter Button Assembly Replacement, Shutter Button Assembly: étape 1, image 1 de 2 Canon PowerShot S400 Shutter Button Assembly Replacement, Shutter Button Assembly: étape 1, image 2 de 2
    • Unless otherwise stated,a #00 philips screwdriver will be used to remove screws.
    • Remove the 4.75mm screw located in the top right corner of the backside of the camera.
    • Remove the four # screws located on the bottom of the camera.
  2. Canon PowerShot S400 Shutter Button Assembly Replacement: étape 2, image 1 de 3 Canon PowerShot S400 Shutter Button Assembly Replacement: étape 2, image 2 de 3 Canon PowerShot S400 Shutter Button Assembly Replacement: étape 2, image 3 de 3
    • Remove the two screws located on the right side of the camera.(the side with the USB adaption plug)
    • Remove the four screws on the left side of the camera.
    • This will release a small metal plate. Remove this plate.
  3. Canon PowerShot S400 Shutter Button Assembly Replacement: étape 3, image 1 de 3 Canon PowerShot S400 Shutter Button Assembly Replacement: étape 3, image 2 de 3 Canon PowerShot S400 Shutter Button Assembly Replacement: étape 3, image 3 de 3
    • There is a small black plastic piece that sits above the lens underneath the camera case. This plastic piece may fall out when you remove the cases; recover the piece and save it.
    • Now separate the front and back camera casings.
  4. Canon PowerShot S400 Shutter Button Assembly Replacement: étape 4, image 1 de 1
    • Using a spudger, carefully pry the shutter button assembly from the camera.
    • Install the replacement shutter button assembly.
Ross Bryan
Membre depuis le 01/21/11
374 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 5-19, Amido Winter 2011 Membre de l'équipe Cal Poly, Team 5-19, Amido Winter 2011
CPSU-AMIDO-W11S5G19
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 2
Total : 2,725
