Aller au contenu principal
Canon PowerShot S50 LCD Screen Replacement
Ce dont vous avez besoin
  1. Canon PowerShot S50 LCD Screen Replacement, Battery: étape 1, image 1 de 2 Canon PowerShot S50 LCD Screen Replacement, Battery: étape 1, image 2 de 2
    • Place camera LCD side up and press up on the battery door.
    • Let it swing open until you can see the battery inside.
  2. Canon PowerShot S50 LCD Screen Replacement: étape 2, image 1 de 1
    • Press down on the orange plastic.
    • This will gently eject the battery from its compartment.
  3. Canon PowerShot S50 LCD Screen Replacement: étape 3, image 1 de 2 Canon PowerShot S50 LCD Screen Replacement: étape 3, image 2 de 2
    • Holding the edges, slide out the battery.
  4. Canon PowerShot S50 LCD Screen Replacement, Front Panel/Battery Door: étape 4, image 1 de 1
    • Look at the camera from the side with the lanyard and 4 screws.
    • Remove the two 3.4 mm screws on the metallic colored part.
  5. Canon PowerShot S50 LCD Screen Replacement: étape 5, image 1 de 1
    • Remove the 3mm screw on the top left.
    • NOTE: When reassembling, it is helpful to put the top screw back in before placing the front cover back on the camera.
    • Now remove the 5.3mm screw on the bottom.
  6. Canon PowerShot S50 LCD Screen Replacement: étape 6, image 1 de 1
    • Place the camera LCD side down.
    • Remove the two 5.3mm screws by the battery door.
  7. Canon PowerShot S50 LCD Screen Replacement: étape 7, image 1 de 1
    • Remove the four 3.4mm screws on the bottom of the camera around the tripod mount.
    • Make sure to keep these screws separate from the previous 5.3 mm screws.
  8. Canon PowerShot S50 LCD Screen Replacement: étape 8, image 1 de 1
    • Stand the camera back up.
    • Remove the two 3.6mm screws on the side with the A/V Out port.
  9. Canon PowerShot S50 LCD Screen Replacement: étape 9, image 1 de 1
    • Lift open the rubber flap covering the A/V Out port.
    • Remove the 3.4mm screw in the center.
    • During reassembly, put the A/V out rubber door on before replacing the front panel of the camera
  10. Canon PowerShot S50 LCD Screen Replacement: étape 10, image 1 de 1
    • Use a spudger and gently open up the front panel of the camera.
    • A thin plastic ribbon will stay connected by a brown piece to front panel of the camera.
  11. Canon PowerShot S50 LCD Screen Replacement: étape 11, image 1 de 1
    • There will be a brown plastic piece keeping the thin plastic ribbon in place.
    • Use the spudger to pull out the brown plastic piece attached to the orange plastic.
  12. Canon PowerShot S50 LCD Screen Replacement: étape 12, image 1 de 1
    Outil utilisé dans cette étape :
    • Use a pair of tweezers and remove the metal piece inside the camera.
  13. Canon PowerShot S50 LCD Screen Replacement: étape 13, image 1 de 1
    • Remove the battery door
    • NOTE: Putting this back on requires aligning the spring on the back of the door with the hole on the camera
  14. Canon PowerShot S50 LCD Screen Replacement, Right Motherboard: étape 14, image 1 de 1
    • Disconnect the two plastic ribbons on the lower half of the right motherboard.
    • NOTE: You will have to lift up the brown plastic piece in order to pull out the second ribbon wire.
  15. Canon PowerShot S50 LCD Screen Replacement: étape 15, image 1 de 1
    • Remove the two 3.4mm screws on the right motherboard.
  16. Canon PowerShot S50 LCD Screen Replacement: étape 16, image 1 de 1
    • Disconnect the two wired plugs below the flash.
  17. Canon PowerShot S50 LCD Screen Replacement: étape 17, image 1 de 1
    • Disconnect the wired plug at the bottom of the right motherboard.
  18. Canon PowerShot S50 LCD Screen Replacement: étape 18, image 1 de 1
    • Use a pair of tweezers to pull the right motherboard away from the main body of the camera.
  19. Canon PowerShot S50 LCD Screen Replacement, Outer Casing: étape 19, image 1 de 1
    • Using a spudger, gently separate the back panel from the rest of the camera and remove it.
  20. Canon PowerShot S50 LCD Screen Replacement, LCD Screen: étape 20, image 1 de 1
    • Remove the 2.6mm screw on the bottom of the camera located directly under the LCD screen.
    • This screw should be holding two pieces of orange film down.
    • When replacing this screw, make sure that the orange film is secure below it before screwing it in.
  21. Canon PowerShot S50 LCD Screen Replacement: étape 21, image 1 de 1
    • Disconnect the film from the bottom of the camera under the LCD Screen.
  22. Canon PowerShot S50 LCD Screen Replacement: étape 22, image 1 de 1
    • Remove the 3.3mm screw on the bottom left of the LCD screen.
  23. Canon PowerShot S50 LCD Screen Replacement: étape 23, image 1 de 1
    • Remove the 2.4mm screw located just to the upper right of the LCD Screen.
  24. Canon PowerShot S50 LCD Screen Replacement: étape 24, image 1 de 1
    • Gently remove the LCD Screen.
Jacob
Membre depuis le 03/29/12
13 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 7-34, Maness Spring 2012 Membre de l'équipe Cal Poly, Team 7-34, Maness Spring 2012
CPSU-MANESS-S12S7G34
5 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 13
Total : 1,468
