Aller au contenu principal
Canon PowerShot S80 Flash Replacement
Ce dont vous avez besoin
  1. Canon PowerShot S80 Flash Replacement, Disassembling Canon PowerShot S80 Outer Casing: étape 1, image 1 de 2 Canon PowerShot S80 Flash Replacement, Disassembling Canon PowerShot S80 Outer Casing: étape 1, image 2 de 2
    • Remove the knot on the wrist lanyard.
    • Remove the battery and the memory card.
  2. Canon PowerShot S80 Flash Replacement: étape 2, image 1 de 2 Canon PowerShot S80 Flash Replacement: étape 2, image 2 de 2
    • Begin removing the screws on the bottom of the outer casing.
    • Next, remove the rest of the screws from the outer casing.
  3. Canon PowerShot S80 Flash Replacement: étape 3, image 1 de 3 Canon PowerShot S80 Flash Replacement: étape 3, image 2 de 3 Canon PowerShot S80 Flash Replacement: étape 3, image 3 de 3
    • Gently pull the front cover off of the camera.
  4. Canon PowerShot S80 Flash Replacement: étape 4, image 1 de 3 Canon PowerShot S80 Flash Replacement: étape 4, image 2 de 3 Canon PowerShot S80 Flash Replacement: étape 4, image 3 de 3
    • Open the "A/V Out Digital" cover. Remove the screw inside.
    • Gently pull off the back casing.
    • Remove the black "L" shaped piece of metal.
  5. Canon PowerShot S80 Flash Replacement, LCD Screen: étape 5, image 1 de 1
    • Remove the three screws that are holding the screen in place. Free the screen from the underlying components.
    • Be careful with the ribbon wire that is still attached on the left side of the screen.
  6. Canon PowerShot S80 Flash Replacement: étape 6, image 1 de 2 Canon PowerShot S80 Flash Replacement: étape 6, image 2 de 2
    • With the spudger, gently lift the black flap that is holding the wide ribbon cable wire in place.
    • Unplug the wide ribbon cable.
    • Unplug the narrow ribbon cable to free the LCD screen from the camera body.
  7. Canon PowerShot S80 Flash Replacement, Flash: étape 7, image 1 de 1
    • Remove the L-shaped corner trim containing the picture button.
    • Carefully unplug the connection cable that is attached.
  8. Canon PowerShot S80 Flash Replacement: étape 8, image 1 de 2 Canon PowerShot S80 Flash Replacement: étape 8, image 2 de 2
    • Pull the selector wheel from the top corner of the camera.
    • Carefully remove the ribbon cable connection with a set of tweezers.
  9. Canon PowerShot S80 Flash Replacement: étape 9, image 1 de 1
    • With a Phillips #00 Screwdriver, unscrew the zoom toggle switch and remove it from the camera.
  10. Canon PowerShot S80 Flash Replacement: étape 10, image 1 de 1
    • With a Phillips #00 Screwdriver, unscrew the flash board.
  11. Canon PowerShot S80 Flash Replacement: étape 11, image 1 de 1
    • Remove the cable connection. With a metal spudger, gently pry up.
    • Remove the ribon cable. With a metal spudger, gently lift up the black tab.
  12. Canon PowerShot S80 Flash Replacement: étape 12, image 1 de 1
    • Lift the flash bulb unit upwards from the camera.
  13. Canon PowerShot S80 Flash Replacement: étape 13, image 1 de 2 Canon PowerShot S80 Flash Replacement: étape 13, image 2 de 2
    • Lift the entire three-part flash assembly from the camera.
BrettH
Membre depuis le 10/28/09
219 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 19-5, Maness SU 2012 Membre de l'équipe Cal Poly, Team 19-5, Maness SU 2012
CPSU-MANESS-SU12S19G5
1 membre
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 4
Total : 3,651
