Aller au contenu principal
Canon PowerShot SD1000 LCD Screen Replacement
Ce dont vous avez besoin
  1. Canon PowerShot SD1000 LCD Screen Replacement, Back Panel: étape 1, image 1 de 2 Canon PowerShot SD1000 LCD Screen Replacement, Back Panel: étape 1, image 2 de 2
    • Remove the two 2.9 mm screws from the side panel closest to the camera lens.
  2. Canon PowerShot SD1000 LCD Screen Replacement: étape 2, image 1 de 1
    • Remove the two 2.9 mm screws from the camera bottom panel.
  3. Canon PowerShot SD1000 LCD Screen Replacement: étape 3, image 1 de 1
    • Remove the two 2.9 mm screws from the side panel farthest from the lens.
  4. Canon PowerShot SD1000 LCD Screen Replacement: étape 4, image 1 de 1
    • Pull the back panel away from the camera body, starting at the end with the function buttons.
  5. Canon PowerShot SD1000 LCD Screen Replacement: étape 5, image 1 de 1
    • Remove the small cover panel and the attached wrist strap mount.
  6. Canon PowerShot SD1000 LCD Screen Replacement, Front Case: étape 6, image 1 de 1
    • Remove the front cover by gently pulling it away from the camera body.
  7. Canon PowerShot SD1000 LCD Screen Replacement: étape 7, image 1 de 1
    • Place the front cover, back cover, and wrist strap mount in a safe place until you are ready for reassembly.
  8. Canon PowerShot SD1000 LCD Screen Replacement, LCD Screen: étape 8, image 1 de 1
    • Remove the two 2.4 mm screws located at the top of the LCD panel.
  9. Canon PowerShot SD1000 LCD Screen Replacement: étape 9, image 1 de 2 Canon PowerShot SD1000 LCD Screen Replacement: étape 9, image 2 de 2
    • Pull up the metal frame surrounding the LCD screen starting at the side of the camera.
  10. Canon PowerShot SD1000 LCD Screen Replacement: étape 10, image 1 de 1
    • Push the metal frame away from the metal tab using the spudger to detach the frame.
    • Rotate the metal frame upwards.
    • The metal framing should be attached by a metal tab towards the bottom of the camera, near the function buttons.
  11. Canon PowerShot SD1000 LCD Screen Replacement: étape 11, image 1 de 2 Canon PowerShot SD1000 LCD Screen Replacement: étape 11, image 2 de 2
    • Carefully lift the metal frame from the camera.
    • Remove the black LCD screen, leaving the thin lens pieces in place.
    • BE CAREFUL; both components are attached by an orange connector ribbon and cannot be removed yet.
  12. Canon PowerShot SD1000 LCD Screen Replacement: étape 12, image 1 de 3 Canon PowerShot SD1000 LCD Screen Replacement: étape 12, image 2 de 3 Canon PowerShot SD1000 LCD Screen Replacement: étape 12, image 3 de 3
    Outil utilisé dans cette étape :
    • Carefully pull on the orange connector ribbon to disconnect the LCD screen.
    • The LCD screen can be pulled out of the frame before disconnecting its connector ribbon.
    • Tweezers are helpful to disconnect the ribbon.
2 autres ont terminé cette réparation.
Phillip Phung
Membre depuis le 01/19/12
651 Réputation
9 tutoriels rédigés
Équipe
Cal Poly, Team 8-18, Maness Winter 2012 Membre de l'équipe Cal Poly, Team 8-18, Maness Winter 2012
CPSU-MANESS-W12S8G18
4 membres
12 tutoriels rédigés
Un commentaire
Very helpful. These units still sell for a lot more than the cost of the replacement LCD
George Francis - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 12
30 derniers jours : 58
Total : 3,975
