Aller au contenu principal
Introduction
Use the guide to remove the flash assembly.
Pièces
Aucune pièce spécifiée.
  1. Remove wrist strap and battery. Remove wrist strap and battery.
    • Remove wrist strap and battery.
  2. Remove 2 screws from each side of the camera (4 total, 0.102 in). Remove 2 screws from the bottom on the camera (0.138 in). Do not mix the 4 side screws with the 2 bottoms ones; they are different sizes.
    • Remove 2 screws from each side of the camera (4 total, 0.102 in).
    • Remove 2 screws from the bottom on the camera (0.138 in).
    • Do not mix the 4 side screws with the 2 bottoms ones; they are different sizes.
  3. Gently pull off the front cover. The plate on the side should come off. Gently pull off the back cover.
    • Gently pull off the front cover.
    • The plate on the side should come off.
    • Gently pull off the back cover.
  4. The cases should now be removed.
    • The cases should now be removed.
  5. Remove the top-left screw above the LCD screen (0.100 in). Remove the C-shaped plate from the side of the LCD screen.
    • Remove the top-left screw above the LCD screen (0.100 in).
    • Remove the C-shaped plate from the side of the LCD screen.
  6. Fix Kits pour Android
    Remplacer l'écran ou la batterie est à portée de kit !
    Acheter maintenant
    Acheter maintenant
  7. Remove the screw from the top-right of the LCD screen (0.098 in). Remove the L-shaped bar from the right of the LCD screen.
    • Remove the screw from the top-right of the LCD screen (0.098 in).
    • Remove the L-shaped bar from the right of the LCD screen.
  8. Use the spudger to remove the L-shaped bar from the left-side of the LCD screen. Use the spudger to remove the L-shaped bar from the left-side of the LCD screen.
    • Use the spudger to remove the L-shaped bar from the left-side of the LCD screen.
  9. Use tweezers to remove the connector ribbon from the top-left corner above the LCD screen.
    • Use tweezers to remove the connector ribbon from the top-left corner above the LCD screen.
    • Be gentle. This ribbon should stay attached to the screen.
  10. Use a spudger to lift the connector lock (black flap) at the end of the larger LCD connector ribbon on the front side of the camera. Use the tweezers to lift this ribbon. Use the tweezers to gently peel this ribbon from the one underneath it.
    • Use a spudger to lift the connector lock (black flap) at the end of the larger LCD connector ribbon on the front side of the camera.
    • Use the tweezers to lift this ribbon.
    • Use the tweezers to gently peel this ribbon from the one underneath it.
  11. The LCD screen should now be removed.
    • The LCD screen should now be removed.
  12. Remove the screw located on the side of the camera (0.072 in).
    • Remove the screw located on the side of the camera (0.072 in).
  13. Use the spudger to remove the lens ribbon from the circuit board. Use the spudger to lift the ribbon.
    • Use the spudger to remove the lens ribbon from the circuit board.
    • Use the spudger to lift the ribbon.
    • This ribbon is connected to the lens, but the flash assembly ribbon is underneath it.
  14. Disconnect the flash assembly ribbon. The flash assembly ribbon is located underneath the lens assembly ribbon.
    • Disconnect the flash assembly ribbon.
    • The flash assembly ribbon is located underneath the lens assembly ribbon.
  15. Remove the flash assembly, which includes the capacitor. If it resists, note the small hook on the right side near the bottom.
    • Remove the flash assembly, which includes the capacitor. If it resists, note the small hook on the right side near the bottom.
    • Be careful when taking out the capacitor. It could shock you.
  16. The capacitor should now be removed.
    • The capacitor should now be removed.
2 autre(s) ont terminé cette réparation.
Tyler Grossheim
Membre depuis le 25/01/2011
1 440 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 3-32, Regan Winter 2011 Membre de l'équipe Cal Poly, Team 3-32, Regan Winter 2011
CPSU-REGAN-W11S3G32
3 membres
8 tutoriels rédigés
Step 14 The little hook at the bottom that holds the flash assembly in is hard to see. It is part of the bracket that holds the flash in and also forms part of the chassis of the camera. I found that you can gently flex the bracket outward ( away from the flash) to release the hook. After that, the flash unit came right out. Also note, that some flash units you get from electronics scrapers on ebay will have the bracket attached to the flash unit and it needs to be removed before you install the replacement part. It seems obvious but then again...
Jamey - Réponse
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 2,936
