Aller au contenu principal
Canon PowerShot SD1100 IS Function Buttons Replacement
Ce dont vous avez besoin
  1. Canon PowerShot SD1100 IS Function Buttons Replacement, Front and Rear Cover: étape 1, image 1 de 2 Canon PowerShot SD1100 IS Function Buttons Replacement, Front and Rear Cover: étape 1, image 2 de 2
    • Remove wrist strap and battery.
  2. Canon PowerShot SD1100 IS Function Buttons Replacement: étape 2, image 1 de 3 Canon PowerShot SD1100 IS Function Buttons Replacement: étape 2, image 2 de 3 Canon PowerShot SD1100 IS Function Buttons Replacement: étape 2, image 3 de 3
    • Remove 2 screws from each side of the camera (4 total, 0.102 in).
    • Remove 2 screws from the bottom on the camera (0.138 in).
    • Do not mix the 4 side screws with the 2 bottoms ones; they are different sizes.
  3. Canon PowerShot SD1100 IS Function Buttons Replacement: étape 3, image 1 de 3 Canon PowerShot SD1100 IS Function Buttons Replacement: étape 3, image 2 de 3 Canon PowerShot SD1100 IS Function Buttons Replacement: étape 3, image 3 de 3
    • Gently pull off the front cover.
    • The plate on the side should come off.
    • Gently pull off the back cover.
  4. Canon PowerShot SD1100 IS Function Buttons Replacement: étape 4, image 1 de 1
    • The cases should now be removed.
  5. Canon PowerShot SD1100 IS Function Buttons Replacement, Top Button Assembly: étape 5, image 1 de 1
    • Use the spudger to disconnect the black tab.
  6. Canon PowerShot SD1100 IS Function Buttons Replacement: étape 6, image 1 de 1
    • Gently pull off the shutter button assembly.
  7. Canon PowerShot SD1100 IS Function Buttons Replacement: étape 7, image 1 de 1
    • Use the tweezers to disconnect the microphone cable.
  8. Canon PowerShot SD1100 IS Function Buttons Replacement: étape 8, image 1 de 1
    • The shutter button assembly should now be removed.
  9. Canon PowerShot SD1100 IS Function Buttons Replacement, Function Buttons: étape 9, image 1 de 1
    • With the spudger, flip up the black tab on the main ribbon.
  10. Canon PowerShot SD1100 IS Function Buttons Replacement: étape 10, image 1 de 2 Canon PowerShot SD1100 IS Function Buttons Replacement: étape 10, image 2 de 2
    • Gently pull straight out on the ribbon to disconnect it from the logic board.
  11. Canon PowerShot SD1100 IS Function Buttons Replacement: étape 11, image 1 de 1
    • By hand, gently unfold the function button board and lift it off the frame.
  12. Canon PowerShot SD1100 IS Function Buttons Replacement: étape 12, image 1 de 1
    • Congratulations! The function button board can now be replaced.
Wyatt Chan
Membre depuis le 01/05/11
235 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 3-32, Regan Winter 2011 Membre de l'équipe Cal Poly, Team 3-32, Regan Winter 2011
CPSU-REGAN-W11S3G32
3 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 2
Total : 1,960
