Aller au contenu principal
Canon PowerShot SD1200 IS Function Button Board Replacement
Ce dont vous avez besoin
  1. Canon PowerShot SD1200 IS Function Button Board Replacement, Front and Rear Covers: étape 1, image 1 de 1
    • Remove the battery.
  2. Canon PowerShot SD1200 IS Function Button Board Replacement: étape 2, image 1 de 3 Canon PowerShot SD1200 IS Function Button Board Replacement: étape 2, image 2 de 3 Canon PowerShot SD1200 IS Function Button Board Replacement: étape 2, image 3 de 3
    • Remove the two screws from the side of the camera casing with the strap. (4mm Phillips 00)
    • Remove the two screws from the bottom of the camera. (4mm Phillips 00)
    • Remove the two screws from the right side of the camera opposite the strap. (2mm Phillips 00)
  3. Canon PowerShot SD1200 IS Function Button Board Replacement: étape 3, image 1 de 2 Canon PowerShot SD1200 IS Function Button Board Replacement: étape 3, image 2 de 2
    • Pull off the front cover.
    • If the top of the cover sticks, use gentle downward pressure on the retention clips above the lens to release.
    • Remove the back cover.
  4. Canon PowerShot SD1200 IS Function Button Board Replacement, Function Buttons: étape 4, image 1 de 1
    • Use the spudger to lift the tab on the Zero Insertion Force (ZIF) connector located at the top of the function button board.
    • Be sure you are prying up on the hinged retaining flap, not the connector itself.
    • Slide out the ribbon cable from the connector.
  5. Canon PowerShot SD1200 IS Function Button Board Replacement: étape 5, image 1 de 1
    • Remove the top screw from the function button board. (3.5mm Phillips 00)
    • Remove the bottom screw from the function button board. (2.5mm Phillips 00)
  6. Canon PowerShot SD1200 IS Function Button Board Replacement: étape 6, image 1 de 1
    • Lift out the function button board.
Jeff Casper
Membre depuis le 09/15/16
897 Réputation
7 tutoriels rédigés
Équipe
USF Tampa, Team 17-5, Blackwell Fall 2016 Membre de l'équipe USF Tampa, Team 17-5, Blackwell Fall 2016
USFT-BLACKWELL-F16S17G5
3 membres
7 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 11
Total : 418
