Aller au contenu principal
Canon PowerShot SD1300 IS Flash Assembly Replacement
Ce dont vous avez besoin
  1. Canon PowerShot SD1300 IS Flash Assembly Replacement, Flash Assembly: étape 1, image 1 de 3 Canon PowerShot SD1300 IS Flash Assembly Replacement, Flash Assembly: étape 1, image 2 de 3 Canon PowerShot SD1300 IS Flash Assembly Replacement, Flash Assembly: étape 1, image 3 de 3
    • Remove the two 2mm J00 screws on the right exterior.
    • Remove a single 4 mm J00 on the bottom exterior.
    • Remove a single 3mm J00 on the left exterior.
  2. Canon PowerShot SD1300 IS Flash Assembly Replacement: étape 2, image 1 de 1
    • Once the front shell of the camera is removed the back shell should slide off just the same.
  3. Canon PowerShot SD1300 IS Flash Assembly Replacement: étape 3, image 1 de 1
    • Remove a 3mm J00 screw from behind wires under the flash.
  4. Canon PowerShot SD1300 IS Flash Assembly Replacement: étape 4, image 1 de 1
    • Use plastic opening tool to remove the screen to gain access to the screws to remove the Flash Assembly.
  5. Canon PowerShot SD1300 IS Flash Assembly Replacement: étape 5, image 1 de 1
    • Remove the two 3mm J00 screws under the screen.
    • Remove the 4mm J00 screws under the screen.
    • The flash assembly is now released and should be able to be removed from the front side of the camera.
Clayton
Membre depuis le 03/20/17
560 Réputation
5 tutoriels rédigés
Équipe
Texas Tech, Team S13-G1, Bennett Spring 2017 Membre de l'équipe Texas Tech, Team S13-G1, Bennett Spring 2017
TTU-BENNETT-S17S13G1
5 membres
5 tutoriels rédigés
0Commentaires sur le guide
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 9
30 derniers jours : 31
Total : 375
