Aller au contenu principal
Canon PowerShot SD30 Screen Replacement
Ce dont vous avez besoin
  1. Canon PowerShot SD30 Screen Replacement, Front Cover: étape 1, image 1 de 2 Canon PowerShot SD30 Screen Replacement, Front Cover: étape 1, image 2 de 2
    • Be sure to remove the wrist strap and battery before removing the cover.
    • Remove the two 2mm black screws that are located on the underside of the camera.
    • Remove the two 3mm silver screws from the right side of camera.
  2. Canon PowerShot SD30 Screen Replacement: étape 2, image 1 de 1
    • Gently remove the front cover.
  3. Canon PowerShot SD30 Screen Replacement, Back Cover: étape 3, image 1 de 3 Canon PowerShot SD30 Screen Replacement, Back Cover: étape 3, image 2 de 3 Canon PowerShot SD30 Screen Replacement, Back Cover: étape 3, image 3 de 3
    • Remove the wrist strap and battery before removing the back cover.
    • Remove the 2mm screw from the back of the camera.
    • Remove two 2mm screws from the bottom of the camera.
    • Remove two 2mm screws the left side of camera.
  4. Canon PowerShot SD30 Screen Replacement: étape 4, image 1 de 1
    • Gently remove the back cover.
  5. Canon PowerShot SD30 Screen Replacement, Screen: étape 5, image 1 de 2 Canon PowerShot SD30 Screen Replacement, Screen: étape 5, image 2 de 2
    • Remove top button panel by removing the screw located at the top right of the panel.
  6. Canon PowerShot SD30 Screen Replacement: étape 6, image 1 de 2 Canon PowerShot SD30 Screen Replacement: étape 6, image 2 de 2
    • Remove screws both at the top and the base of the screen to free the screen.
  7. Canon PowerShot SD30 Screen Replacement: étape 7, image 1 de 3 Canon PowerShot SD30 Screen Replacement: étape 7, image 2 de 3 Canon PowerShot SD30 Screen Replacement: étape 7, image 3 de 3
    • Use tweezers to lift the tab that secures the screen wire and remove.
    • You need to do this for both wires.
2 autres ont terminé cette réparation.
Erin Brophy
Membre depuis le 09/21/18
124 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 137
