Aller au contenu principal
Canon PowerShot SD400 LCD Replacement
Ce dont vous avez besoin
  1. Canon PowerShot SD400 LCD Replacement, Battery: étape 1, image 1 de 2 Canon PowerShot SD400 LCD Replacement, Battery: étape 1, image 2 de 2
    • Slide the battery cover open (indicated by the red box).
  2. Canon PowerShot SD400 LCD Replacement: étape 2, image 1 de 1
    • Push in the orange clip (indicated by the red box) to eject the battery.
  3. Canon PowerShot SD400 LCD Replacement: étape 3, image 1 de 1
    • Insert the charged battery back into the slot (indicated by the red box).
    • Close the cover.
  4. Canon PowerShot SD400 LCD Replacement, LCD: étape 4, image 1 de 3 Canon PowerShot SD400 LCD Replacement, LCD: étape 4, image 2 de 3 Canon PowerShot SD400 LCD Replacement, LCD: étape 4, image 3 de 3
    • Locate these six screws that need to be removed to open the camera’s housing. These screws can be found on the bottom and both sides of the camera.
  5. Canon PowerShot SD400 LCD Replacement: étape 5, image 1 de 3 Canon PowerShot SD400 LCD Replacement: étape 5, image 2 de 3 Canon PowerShot SD400 LCD Replacement: étape 5, image 3 de 3
    • Using the screwdriver, carefully remove the exterior screws and place them in a safe location to avoid misplacing them.
  6. Canon PowerShot SD400 LCD Replacement: étape 6, image 1 de 2 Canon PowerShot SD400 LCD Replacement: étape 6, image 2 de 2
    • Locate the interior screw that is above the top right of the LCD screen.
    • Remove the screw using the screwdriver.
  7. Canon PowerShot SD400 LCD Replacement: étape 7, image 1 de 3 Canon PowerShot SD400 LCD Replacement: étape 7, image 2 de 3 Canon PowerShot SD400 LCD Replacement: étape 7, image 3 de 3
    • Locate the two clips on the left side of the LCD screen.
    • Carefully insert the tip of a flat-head screwdriver under the two clips of the LCD screen.
    • Slowly lift the screen using the flat-head screwdriver.
    • Potential for device damage Lift the screen gently to avoid any damage.
2 autres ont terminé cette réparation.
Yi Huang Ke
Membre depuis le 10/18/11
51 Réputation
4 tutoriels rédigés
Équipe
James Madison, Team 1-1, Allen Fall 2011 Membre de l'équipe James Madison, Team 1-1, Allen Fall 2011
JMU-ALLEN-F11S1G1
4 membres
4 tutoriels rédigés
1 commentaire de tutoriel
Do you carry a lcd screen for the Powershot sd400?
Jesus Licon - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 9
Total : 3,625
