Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Introduction
Remove the back cover before removing LCD.
Pièces
Aucune pièce spécifiée.
  1. Remove one 2.25mm screw on the bottom.
    • Remove one 2.25mm screw on the bottom.
  2. Remove two 2.25mm screws on the right side looking from the front.
    • Remove two 2.25mm screws on the right side looking from the front.
  3. Remove one 4.7mm screw on the side with the AV output.
    • Remove one 4.7mm screw on the side with the AV output.
  4. SAUTEZ LA MISE À NIVEAU
    Économisez en réparant avec un kit tout-en-un.
    Fix Kits pour iPhone
  5. Pull off the back cover.
    • Pull off the back cover.
    • The back cover tends to stick in the top corner (near the mode dial) due to a metal clip. Jiggle the cover side to side as you pull it out.
  6. Remove 2 2.4mm screws on bottom.
    • Remove 2 2.4mm screws on bottom.
  7. Follow the small data cable to where it connects to the camera.
    • Follow the small data cable to where it connects to the camera.
    • Lift the back white portion to unlock the cable.
    • The cable should easily slide out.
    • The connector is very fragile. Use caution when lifting the lock.
  8. Gently lift LCD display off.
    • Gently lift LCD display off.
    • There will be two data cables still attached to the camera. Do not break them.
    • There may be a loose strip of metal along the inner side of the LCD display for a secure fit.
  9. Follow the larger cable to where it connects to the camera.
    • Follow the larger cable to where it connects to the camera.
    • Lift the front black portion of the connector to unlock the data cable.
2 autre(s) ont terminé cette réparation.
Jeremy Rabaino
Membre depuis le 10/10/2010
135 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 20-9, Maness Fall 2010 Membre de l'équipe Cal Poly, Team 20-9, Maness Fall 2010
CPSU-MANESS-F10S20G9
5 membres
6 tutoriels rédigés
where can I buy a replacement LCD screen for a SD800 IS
ALFRED - Réponse
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 2,129
