Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Introduction
How to remove the outer casing of your Canon PowerShot SD870 IS.
Pièces
Aucune pièce spécifiée.
  1. Remove the wrist strap, if present.
    • Remove the wrist strap, if present.
    • Remove the lithium-ion battery.
  2. Remove the two 4 mm Phillips #00 screws on the bottom of the camera. Remove the screw next to the wrist strap attachment. Pull up the “A/V OUT DIGITAL” cover and remove the screw above the USB port.
    • Remove the two 4 mm Phillips #00 screws on the bottom of the camera.
    • Remove the screw next to the wrist strap attachment.
    • Pull up the “A/V OUT DIGITAL” cover and remove the screw above the USB port.
  3. Fix Kits pour écrans LCD d'iPhone
    L'option économique couverte par notre garantie à vie.
    Acheter des kits
    Réduisez les coûts de réparation et non pas la qualité.
    Acheter des kits
  4. Carefully unhook the “A/V OUT DIGITAL” cover from the hinge.
    • Carefully unhook the “A/V OUT DIGITAL” cover from the hinge.
  5. Pull the front cover from the camera by  using gentle upward pressure. Pull the front cover from the camera by  using gentle upward pressure.
    • Pull the front cover from the camera by using gentle upward pressure.
  6. Remove the two Phillips #00 screws from the flat end of the camera. Remove the black L-shaped side cover plate.
    • Remove the two Phillips #00 screws from the flat end of the camera.
    • Remove the black L-shaped side cover plate.
    • Remove the silver u-shaped retainer plate.
  7. Slide the back casing off.
    • Slide the back casing off.
2 autre(s) ont terminé cette réparation.
Zach pelley
Membre depuis le 19/04/2010
67 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 10-45, Garner Spring 2010 Membre de l'équipe Cal Poly, Team 10-45, Garner Spring 2010
CPSU-GARNER-S10S10G45
4 membres
6 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 2
7 derniers jours : 7
30 derniers jours : 12
Total : 7,880
