Aller au contenu principal
Canon PowerShot SX150 IS Digital Image Sensor Replacement
Ce dont vous avez besoin
  1. Canon PowerShot SX150 IS Digital Image Sensor Replacement, Canon PowerShot SX150 IS Battery Removal: étape 1, image 1 de 3 Canon PowerShot SX150 IS Digital Image Sensor Replacement, Canon PowerShot SX150 IS Battery Removal: étape 1, image 2 de 3 Canon PowerShot SX150 IS Digital Image Sensor Replacement, Canon PowerShot SX150 IS Battery Removal: étape 1, image 3 de 3
    • Locate the battery cover on the bottom of the camera.
    • Slide the battery compartment cover the direction the arrow is pointing to open the compartment.
    • Remove batteries.
  2. Canon PowerShot SX150 IS Digital Image Sensor Replacement, Canon PowerShot SX150 IS Prerequisite: étape 2, image 1 de 1
    • Remove the two 2mm screws above the screen using the size J000 screwdriver.
  3. Canon PowerShot SX150 IS Digital Image Sensor Replacement: étape 3, image 1 de 2 Canon PowerShot SX150 IS Digital Image Sensor Replacement: étape 3, image 2 de 2
    • Remove the two 5mm screws from the side of the camera with the J000 head screw driver.
    • Using the same screwdriver, remove the one 5mm screw from the other side of the camera located under the A/V Out flap.
  4. Canon PowerShot SX150 IS Digital Image Sensor Replacement: étape 4, image 1 de 1
    • Remove two 4mm screws from the bottom of the camera with the J000 head screw driver.
  5. Canon PowerShot SX150 IS Digital Image Sensor Replacement: étape 5, image 1 de 1
    • Remove the plastic panel surrounding the back screen.
  6. Canon PowerShot SX150 IS Digital Image Sensor Replacement: étape 6, image 1 de 3 Canon PowerShot SX150 IS Digital Image Sensor Replacement: étape 6, image 2 de 3 Canon PowerShot SX150 IS Digital Image Sensor Replacement: étape 6, image 3 de 3
    Outil utilisé dans cette étape :
    • Remove the three 3mm screws using the size J000 screw driver from the button plate.
    • Gently flip up the flex ribbon lock and remove the flex ribbon using tweezers.
    • Move the button plate out of the way.
  7. Canon PowerShot SX150 IS Digital Image Sensor Replacement: étape 7, image 1 de 2 Canon PowerShot SX150 IS Digital Image Sensor Replacement: étape 7, image 2 de 2
    • There is a black flex ribbon lock that must be lifted and unlocked with your tweezers before this flex ribbon will detach.
    • Any small tear could ruin the flex ribbon. Be very gentle while removing it.
    • Gently lift the lock and detach the flex ribbon from the circuit board with the tweezers.
  8. Canon PowerShot SX150 IS Digital Image Sensor Replacement: étape 8, image 1 de 1
    • Remove the two 2mm screws from the bottom of the screen with the size J000 screw driver.
    • You can then lift the screen out of place and set it aside.
  9. Canon PowerShot SX150 IS Digital Image Sensor Replacement: étape 9, image 1 de 3 Canon PowerShot SX150 IS Digital Image Sensor Replacement: étape 9, image 2 de 3 Canon PowerShot SX150 IS Digital Image Sensor Replacement: étape 9, image 3 de 3
    • With the J000 Philips head screwdriver, remove the two 2mm screws from under the flash.
    • Using the same screwdriver, remove the two 5mm screws from the bottom. One is under the battery door.
    • With the same screwdriver, remove the 2mm screw at the top of the metal plate.
  10. Canon PowerShot SX150 IS Digital Image Sensor Replacement: étape 10, image 1 de 2 Canon PowerShot SX150 IS Digital Image Sensor Replacement: étape 10, image 2 de 2
    • Gently detach the flex ribbon with your tweezers before removing the front plate.
  11. Canon PowerShot SX150 IS Digital Image Sensor Replacement: étape 11, image 1 de 3 Canon PowerShot SX150 IS Digital Image Sensor Replacement: étape 11, image 2 de 3 Canon PowerShot SX150 IS Digital Image Sensor Replacement: étape 11, image 3 de 3
    • Using the J000 Philips head screwdriver, remove the four 7mm screws from the silver panel.
    • Remove the two 5mm screws.
    • Remove the one 3 mm screw.
    • Using the same screwdriver, remove the 3mm screw from the top of the camera.
    • Pull the panel off and set it aside.
  12. Canon PowerShot SX150 IS Digital Image Sensor Replacement, Digital Image Sensor: étape 12, image 1 de 2 Canon PowerShot SX150 IS Digital Image Sensor Replacement, Digital Image Sensor: étape 12, image 2 de 2
    • Lift the two flex ribbons with your tweezers and remove them.
    • Move the circuit board to the side.
  13. Canon PowerShot SX150 IS Digital Image Sensor Replacement: étape 13, image 1 de 2 Canon PowerShot SX150 IS Digital Image Sensor Replacement: étape 13, image 2 de 2
    • Remove the three 2 mm screws from around the sensor.
    • Pull the sensor away.
3 autres ont terminé cette réparation.
Avery Hyde
Membre depuis le 09/12/16
146 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 18
30 derniers jours : 37
Total : 982
