Ce dont vous avez besoin
Locate the battery cover on the bottom of the camera.
Slide the battery compartment cover the direction the arrow is pointing to open the compartment.
Remove batteries.
Remove the two 2mm screws above the screen using the size J000 screwdriver.
First, very carefully open the latch on each of the three flex ribbons (two black, one brown).
With tweezers, very carefully detach all three flex ribbons from their ports.
Carefully detach the flex ribbon from the side.
