Aller au contenu principal
Canon PowerShot SX160 IS Function Wheel Replacement
Ce dont vous avez besoin
  1. Canon PowerShot SX160 IS Function Wheel Replacement, Function Wheel: étape 1, image 1 de 3 Canon PowerShot SX160 IS Function Wheel Replacement, Function Wheel: étape 1, image 2 de 3 Canon PowerShot SX160 IS Function Wheel Replacement, Function Wheel: étape 1, image 3 de 3
    • Unscrew the 2-4.8mm black Phillips head screws from the front of the camera using a #0 Phillips screwdriver.
    • Unscrew the 2-4.8mm black Phillips head screws from the side of the camera using a #0 Phillips screwdriver.
    • Unscrew the 3-4.8mm black Phillips head screws from the bottom of the camera using a #0 Phillips screwdriver.
  2. Canon PowerShot SX160 IS Function Wheel Replacement: étape 2, image 1 de 2 Canon PowerShot SX160 IS Function Wheel Replacement: étape 2, image 2 de 2
    • Using your hands, gently separate the back panel from the camera.
    • Continue to pull the back panel until it completely detaches from the camera.
  3. Canon PowerShot SX160 IS Function Wheel Replacement: étape 3, image 1 de 2 Canon PowerShot SX160 IS Function Wheel Replacement: étape 3, image 2 de 2
    • Use a #0 phillips screwdriver to unscrew the 3-3.75mm silver Phillips head screws from the function wheel panel of the camera.
  4. Canon PowerShot SX160 IS Function Wheel Replacement: étape 4, image 1 de 1
    • Remove and replace the function wheel.
Congratulations, you have successfully replaced your function wheel. To reassemble your device, follow these instructions in reverse order.
Jamie Secretan
Membre depuis le 03/11/15
1 962 Réputation
6 tutoriels rédigés
Équipe
Colorado Springs, Team 2-3, Panko Spring 2015 Membre de l'équipe Colorado Springs, Team 2-3, Panko Spring 2015
UCCS-PANKO-S15S2G3
3 membres
6 tutoriels rédigés
Un commentaire
Hi, I replaced the LCD screen but now my function wheel and panel don’t work. I think the ribbon got disconnected , but I can’t figure out where to attach it. Can you help?
Denise Domian - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 14
Total : 589
