Aller au contenu principal
Canon PowerShot SX160 IS LCD Replacement
Ce dont vous avez besoin
  1. Canon PowerShot SX160 IS LCD Replacement, LCD: étape 1, image 1 de 3 Canon PowerShot SX160 IS LCD Replacement, LCD: étape 1, image 2 de 3 Canon PowerShot SX160 IS LCD Replacement, LCD: étape 1, image 3 de 3
    • Unscrew the 2-4.8mm black screws from the front of the camera using a #0 Phillips head screw driver.
    • Unscrew the 2-4.8mm black screws from the side of the camera using a #0 Phillips head screw driver.
    • Unscrew the 3-4.8mm black screws from the bottom of the camera using a #0 Phillips head screw driver.
  2. Canon PowerShot SX160 IS LCD Replacement: étape 2, image 1 de 2 Canon PowerShot SX160 IS LCD Replacement: étape 2, image 2 de 2
    • Use your hand to gently separate the back panel from the camera.
    • Continue to pull the panel until it becomes completely detached from the camera.
  3. Canon PowerShot SX160 IS LCD Replacement: étape 3, image 1 de 2 Canon PowerShot SX160 IS LCD Replacement: étape 3, image 2 de 2
    • Unscrew the 3-3.75mm silver screws from the function wheel panel of the camera using a #0 Phillips head screw driver.
    • Remove the function wheel panel from the camera and set aside.
  4. Canon PowerShot SX160 IS LCD Replacement: étape 4, image 1 de 1
    • Unlatch the LCD ribbon connector from the camera by gently lifting up on the ribbon while pulling away from the camera.
    • Be extra cautious not to tear the ribbon.
  5. Canon PowerShot SX160 IS LCD Replacement: étape 5, image 1 de 1
    • Using your hand, pull the LCD screen away from the camera and replace.
Congratulations, you have successfully replaced your LCD screen. To reassemble your device, follow these instructions in reverse order.
2 autres ont terminé cette réparation.
Jamie Secretan
Membre depuis le 03/11/15
1 990 Réputation
6 tutoriels rédigés
Équipe
Colorado Springs, Team 2-3, Panko Spring 2015 Membre de l'équipe Colorado Springs, Team 2-3, Panko Spring 2015
UCCS-PANKO-S15S2G3
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 8
30 derniers jours : 34
Total : 1,523
