Aller au contenu principal
Canon PowerShot SX160 IS Outer Case Replacement
Ce dont vous avez besoin
  1. Canon PowerShot SX160 IS Outer Case Replacement, Outer Case: étape 1, image 1 de 3 Canon PowerShot SX160 IS Outer Case Replacement, Outer Case: étape 1, image 2 de 3 Canon PowerShot SX160 IS Outer Case Replacement, Outer Case: étape 1, image 3 de 3
    • Unscrew 2-4.8mm black screws from the front of the camera using a #0 Phillips screwdriver.
    • Unscrew 2-4.8mm black screws from the side of the camera using a #0 Phillips screwdriver.
    • Unscrew 2-4.8mm black screws from the bottom of the camera using a #0 Phillips screwdriver.
  2. Canon PowerShot SX160 IS Outer Case Replacement: étape 2, image 1 de 2 Canon PowerShot SX160 IS Outer Case Replacement: étape 2, image 2 de 2
    • Using your hands, gently separate the back panel from the camera.
    • Continue to pull the back panel until it completely detaches from the camera.
  3. Canon PowerShot SX160 IS Outer Case Replacement: étape 3, image 1 de 2 Canon PowerShot SX160 IS Outer Case Replacement: étape 3, image 2 de 2
    • Use your hands to gently separate the front panel from the camera.
    • Continue to pull the front panel until it completely detaches from the camera.
2 autres ont terminé cette réparation.
Jamie Secretan
Membre depuis le 03/11/15
1 990 Réputation
6 tutoriels rédigés
Équipe
Colorado Springs, Team 2-3, Panko Spring 2015 Membre de l'équipe Colorado Springs, Team 2-3, Panko Spring 2015
UCCS-PANKO-S15S2G3
3 membres
6 tutoriels rédigés
Un commentaire
guide is missing removal of several screws. Four silver screws for front cover. I removed a total of 12 screws to remove covers. Guide only shows 6. Also requires disconnection of flex strip attached to front cover, from below wheel
Stewie Wewie - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 11
30 derniers jours : 27
Total : 1,970
