Aller au contenu principal
Canon PowerShot SX160 IS Shutter Button Replacement
Ce dont vous avez besoin
  1. Canon PowerShot SX160 IS Shutter Button Replacement, Shutter Button: étape 1, image 1 de 3 Canon PowerShot SX160 IS Shutter Button Replacement, Shutter Button: étape 1, image 2 de 3 Canon PowerShot SX160 IS Shutter Button Replacement, Shutter Button: étape 1, image 3 de 3
    • Unscrew 2-4.8mm black screws from the front of the camera using a #0 Phillips screwdriver.
    • Unscrew 2-4.8mm black screws from the side of the camera using a #0 Phillips screwdriver.
    • Unscrew 2-4.8mm black screws from the bottom of the camera using a #0 Phillips screwdriver.
  2. Canon PowerShot SX160 IS Shutter Button Replacement: étape 2, image 1 de 2 Canon PowerShot SX160 IS Shutter Button Replacement: étape 2, image 2 de 2
    • Using your hands, gently separate the back panel from the camera.
    • Continue to pull the back panel until it completely detaches from the camera.
  3. Canon PowerShot SX160 IS Shutter Button Replacement: étape 3, image 1 de 2 Canon PowerShot SX160 IS Shutter Button Replacement: étape 3, image 2 de 2
    • Use your hands to gently separate the front panel from the camera.
    • Continue to pull the front panel until it completely detaches from the camera.
  4. Canon PowerShot SX160 IS Shutter Button Replacement: étape 4, image 1 de 1
    • Locate and replace the shutter button on the front panel of the camera.
Congratulations, you have successfully replaced your shutter button. To reassemble your device, follow these instructions in reverse order.
2 autres ont terminé cette réparation.
Jamie Secretan
Membre depuis le 03/11/15
1 990 Réputation
6 tutoriels rédigés
Équipe
Colorado Springs, Team 2-3, Panko Spring 2015 Membre de l'équipe Colorado Springs, Team 2-3, Panko Spring 2015
UCCS-PANKO-S15S2G3
3 membres
6 tutoriels rédigés
2 commentaires
Great guide on how to replace the shutter button. Where can I get the new button?
mess857 - Réponse
did you ever figure out where to get a new button?
christinapayne1@icloud.com -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 10
30 derniers jours : 45
Total : 3,075
