Aller au contenu principal
Canon PowerShot SX170 IS Disassembly
Ce dont vous avez besoin
  1. Canon PowerShot SX170 IS Disassembly, Case: étape 1, image 1 de 3 Canon PowerShot SX170 IS Disassembly, Case: étape 1, image 2 de 3 Canon PowerShot SX170 IS Disassembly, Case: étape 1, image 3 de 3
    • Remove the screws that secure the back panel using a Phillips screwdriver.
    • Remove screws on the bottom, left and right sides of the camera using a Phillips screwdriver.
    • Pull back the rubber facing to access the screw.
  2. Canon PowerShot SX170 IS Disassembly, Case: étape 2, image 1 de 2 Canon PowerShot SX170 IS Disassembly, Case: étape 2, image 2 de 2
    • Once all screws are removed, open up the back case with a plastic opener from the left side.
  3. Canon PowerShot SX170 IS Disassembly, Function Wheel: étape 3, image 1 de 3 Canon PowerShot SX170 IS Disassembly, Function Wheel: étape 3, image 2 de 3 Canon PowerShot SX170 IS Disassembly, Function Wheel: étape 3, image 3 de 3
    • Remove the screws that secure the small metal plate using a Phillips screwdriver.
    • Gently flip up the flex ribbon lock and remove the flex ribbon.
  4. Canon PowerShot SX170 IS Disassembly, Screen: étape 4, image 1 de 3 Canon PowerShot SX170 IS Disassembly, Screen: étape 4, image 2 de 3 Canon PowerShot SX170 IS Disassembly, Screen: étape 4, image 3 de 3
    • Lift the screen to the left.
  5. Canon PowerShot SX170 IS Disassembly, Front Case: étape 5, image 1 de 2 Canon PowerShot SX170 IS Disassembly, Front Case: étape 5, image 2 de 2
  6. Canon PowerShot SX170 IS Disassembly, Front Case: étape 6, image 1 de 3 Canon PowerShot SX170 IS Disassembly, Front Case: étape 6, image 2 de 3 Canon PowerShot SX170 IS Disassembly, Front Case: étape 6, image 3 de 3
    • Remove the screws below the flash and on the left sides of the camera using a Phillips screwdriver.
    • Leave the flash unfolded.
    • Pull the front case forward.
  7. Canon PowerShot SX170 IS Disassembly, Metal Frame: étape 7, image 1 de 3 Canon PowerShot SX170 IS Disassembly, Metal Frame: étape 7, image 2 de 3 Canon PowerShot SX170 IS Disassembly, Metal Frame: étape 7, image 3 de 3
    • Remove all marked screws using a Phillips screwdriver.
    • Remove the small metal part.
  8. Canon PowerShot SX170 IS Disassembly, Cable: étape 8, image 1 de 3 Canon PowerShot SX170 IS Disassembly, Cable: étape 8, image 2 de 3 Canon PowerShot SX170 IS Disassembly, Cable: étape 8, image 3 de 3
    • Remove the microphone.
    • Remove the flex ribbon.
    • Remove the flash switch.
  9. Canon PowerShot SX170 IS Disassembly, Metal Frame: étape 9, image 1 de 3 Canon PowerShot SX170 IS Disassembly, Metal Frame: étape 9, image 2 de 3 Canon PowerShot SX170 IS Disassembly, Metal Frame: étape 9, image 3 de 3
    • Remove the screw using a Phillips screwdriver.
    • Lift the flash a little to remove the metal frame.
  10. Canon PowerShot SX170 IS Disassembly, Lens Cable: étape 10, image 1 de 3 Canon PowerShot SX170 IS Disassembly, Lens Cable: étape 10, image 2 de 3 Canon PowerShot SX170 IS Disassembly, Lens Cable: étape 10, image 3 de 3
  11. Canon PowerShot SX170 IS Disassembly, Lens Cable: étape 11, image 1 de 2 Canon PowerShot SX170 IS Disassembly, Lens Cable: étape 11, image 2 de 2
    • Remove flex ribbon and light sensor.
  12. Canon PowerShot SX170 IS Disassembly, Lens Screws: étape 12, image 1 de 3 Canon PowerShot SX170 IS Disassembly, Lens Screws: étape 12, image 2 de 3 Canon PowerShot SX170 IS Disassembly, Lens Screws: étape 12, image 3 de 3
    • Remove the screws using a Phillips screwdriver.
    • Lift up the back case.
  13. Canon PowerShot SX170 IS Disassembly, Lens and Sensor: étape 13, image 1 de 2 Canon PowerShot SX170 IS Disassembly, Lens and Sensor: étape 13, image 2 de 2
    • Now you can clean the lens.
JockiToru
Membre depuis le 12/30/20
217 Réputation
1 tutoriel rédigé
3 commentaires
Hello JockiToru! Thanks for the guide.
I took the liberty to correct 'lense' to 'lens'... You can have many lenses, but only one lens!
Also 'bellow' is an air pumping device. I suspect you meant 'lower', so the word is 'below'.
Again, thanks and I will be testing you disassembly, as there seems to be an annoying small insect in my camera.
Jon - Réponse
Hello Jon,
thank you very much for your feedback. I hope you were able to remove that insect.
JockiToru -
Thank you for the guide! my SX170 is taking shots properly again, had to clean the lens after it was kept for a long time, it saved me the cost to bring it to a shop to have it cleaned.
Benedick Brian Cartera - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 16
30 derniers jours : 44
Total : 759
