Aller au contenu principal
Canon PowerShot SX260 HS Battery Replacement
Ce dont vous avez besoin
  1. Canon PowerShot SX260 HS Battery Replacement, Battery: étape 1, image 1 de 1
    • With the device fully assembled, hold the camera with both hands with the bottom of the camera facing toward you.
  2. Canon PowerShot SX260 HS Battery Replacement: étape 2, image 1 de 2 Canon PowerShot SX260 HS Battery Replacement: étape 2, image 2 de 2
    • Place your right thumb on the sliding panel that is marked Card/Battery
    • Slide the panel to your right and you will hear a slight click. This is normal and you did not damage the device.
  3. Canon PowerShot SX260 HS Battery Replacement: étape 3, image 1 de 1
    • Remove your thumb from the Card/Battery panel and lift the panel 90 degrees.
    • The battery will eject slightly by the force of a spring.
    • Remove the battery and replace.
Tyler Kelch
Membre depuis le 03/05/15
622 Réputation
4 tutoriels rédigés
Équipe
Sam Houston State, Team 11-8, Blackburne Winter 2015 Membre de l'équipe Sam Houston State, Team 11-8, Blackburne Winter 2015
SHSU-BLACKBURNE-W15S11G8
2 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 18
Total : 1,079
