Aller au contenu principal
Canon PowerShot SX260 HS Flash Assembly Replacement
Ce dont vous avez besoin
  1. Canon PowerShot SX260 HS Flash Assembly Replacement, Flash Assembly: étape 1, image 1 de 3 Canon PowerShot SX260 HS Flash Assembly Replacement, Flash Assembly: étape 1, image 2 de 3 Canon PowerShot SX260 HS Flash Assembly Replacement, Flash Assembly: étape 1, image 3 de 3
    • Be sure to always remove the battery from the camera before disassembling to avoid permanent damage.
    • The camera has a total of 6 (3 mm) external screws that will need to be removed; 2 on the left side, 2 on the bottom, and 2 on the right side.
    • Remove the 2 screws on the left side.
    • Remove the 2 screws on the bottom of the camera.
    • Remove the 2 screws on the right side of the camera.
  2. Canon PowerShot SX260 HS Flash Assembly Replacement: étape 2, image 1 de 1
    • Use your plastic opening tool to gently lift and remove the back face plate.
  3. Canon PowerShot SX260 HS Flash Assembly Replacement: étape 3, image 1 de 1
    • After removing the exterior screws, use your fingers to gently lift off the front face plate.
  4. Canon PowerShot SX260 HS Flash Assembly Replacement: étape 4, image 1 de 1
    • Next, remove the 2 (3 mm) interior screws on the left side of the camera.
  5. Canon PowerShot SX260 HS Flash Assembly Replacement: étape 5, image 1 de 1
    • After removing the interior left screws, use a plastic opening tool to gently pull the top face plate off.
  6. Canon PowerShot SX260 HS Flash Assembly Replacement: étape 6, image 1 de 1
    • Next, you will need to remove the dial panel by removing the 2 (3mm) screws on the back side of the camera.
    • Gently remove the dial panel with your fingers.
  7. Canon PowerShot SX260 HS Flash Assembly Replacement: étape 7, image 1 de 2 Canon PowerShot SX260 HS Flash Assembly Replacement: étape 7, image 2 de 2
    • Remove 1 (3 mm) screw from the flash generator with a Phillips screw driver
    • Gently lift the flash generator off of the camera with the plastic opening tool .
  8. Canon PowerShot SX260 HS Flash Assembly Replacement: étape 8, image 1 de 1
    Outil utilisé dans cette étape :
    J'achète
    • Gently unplug the ribbon cable with your tweezers.
    • Be careful not to rip it.
  9. Canon PowerShot SX260 HS Flash Assembly Replacement: étape 9, image 1 de 2 Canon PowerShot SX260 HS Flash Assembly Replacement: étape 9, image 2 de 2
    • Using your plastic opening tool to gently move the plug lock from the end of the ribbon cord by lifting it upward.
    • Gently remove the ribbon cable from the connector with tweezers.
  10. Canon PowerShot SX260 HS Flash Assembly Replacement: étape 10, image 1 de 2 Canon PowerShot SX260 HS Flash Assembly Replacement: étape 10, image 2 de 2
    • Gently remove the ribbon cable assembly from the top of the camera with your tweezers.
    • This cable is a long piece that runs across the top of the camera.
    • The flash assembly is connected to this cable.
    • Once removed gently lift out of the camera
    • Replace the ribbon cable with the attached flash assembly.
Tyler Kelch
Membre depuis le 03/05/15
622 Réputation
4 tutoriels rédigés
Équipe
Sam Houston State, Team 11-8, Blackburne Winter 2015 Membre de l'équipe Sam Houston State, Team 11-8, Blackburne Winter 2015
SHSU-BLACKBURNE-W15S11G8
2 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 30
Total : 1,710
