Aller au contenu principal
Canon PowerShot SX260 HS LCD Screen Replacement
Ce dont vous avez besoin
  1. Canon PowerShot SX260 HS LCD Screen Replacement, LCD Screen: étape 1, image 1 de 3 Canon PowerShot SX260 HS LCD Screen Replacement, LCD Screen: étape 1, image 2 de 3 Canon PowerShot SX260 HS LCD Screen Replacement, LCD Screen: étape 1, image 3 de 3
    • Be sure to always remove the battery from the camera before disassembling to avoid permanent damage.
    • The camera has a total of 6 (3 mm) external screws that will need to be removed; 2 on the left side, 2 on the bottom, and 2 on the right side.
    • Remove the 2 (3 mm) screws on the left side
    • Remove the 2 (3 mm) screws on the bottom of the camera.
    • Remove the 2 (3 mm) screws on the right side of the camera.
  2. Canon PowerShot SX260 HS LCD Screen Replacement: étape 2, image 1 de 1
    • Use your plastic opening tool to gently lift and remove back face plate.
    • Unplug the ribbon cable leading to the mode dial.
  3. Canon PowerShot SX260 HS LCD Screen Replacement: étape 3, image 1 de 1
    • After removing exterior screws, gently lift off the front face plate with your fingers.
  4. Canon PowerShot SX260 HS LCD Screen Replacement: étape 4, image 1 de 1
    • Remove the 4 (3 mm) screws that are under the face plate.
  5. Canon PowerShot SX260 HS LCD Screen Replacement: étape 5, image 1 de 1
    • Next, remove the 2 (3 mm) interior screws on the left side of the camera.
  6. Canon PowerShot SX260 HS LCD Screen Replacement: étape 6, image 1 de 1
    • After removing the interior left screws, use a plastic opening tool to gently pull the top face plate off.
  7. Canon PowerShot SX260 HS LCD Screen Replacement: étape 7, image 1 de 1
    • Next,take off the 2 (3mm) screws on the back side of the camera to remove the dial panel.
    • Gently lift the panel with your fingers.
    • Be careful not to rip the attached yellow ribbon cable.
  8. Canon PowerShot SX260 HS LCD Screen Replacement: étape 8, image 1 de 1
    Outil utilisé dans cette étape :
    J'achète
    • Carefully unplug the yellow ribbon cable from the front of the camera using your tweezers.
  9. Canon PowerShot SX260 HS LCD Screen Replacement: étape 9, image 1 de 1
    • Gently slide the LCD screen to the right and remove.
3 autres ont terminé cette réparation.
Tyler Kelch
Membre depuis le 03/05/15
622 Réputation
4 tutoriels rédigés
Équipe
Sam Houston State, Team 11-8, Blackburne Winter 2015 Membre de l'équipe Sam Houston State, Team 11-8, Blackburne Winter 2015
SHSU-BLACKBURNE-W15S11G8
2 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 8
30 derniers jours : 40
Total : 3,832
