Aller au contenu principal
Canon PowerShot SX280 HS LCD Screen Replacement
Ce dont vous avez besoin
  1. Canon PowerShot SX280 HS LCD Screen Replacement, LCD Screen: étape 1, image 1 de 1
    • Turn off the camera and remove the battery.
  2. Canon PowerShot SX280 HS LCD Screen Replacement: étape 2, image 1 de 1
    • Use a Phillips #00 screwdriver to remove the two 3.4 mm screws on the left side of the camera.
  3. Canon PowerShot SX280 HS LCD Screen Replacement: étape 3, image 1 de 1
    • Using the same screwdriver, remove the two 3.4 mm screws on the bottom of the camera.
  4. Canon PowerShot SX280 HS LCD Screen Replacement: étape 4, image 1 de 1
    • Lift the small plastic tab, located on the front of the camera, to remove the GPS cover.
  5. Canon PowerShot SX280 HS LCD Screen Replacement: étape 5, image 1 de 1
    • Using the same Phillips screwdriver, remove the two screws that hold the LCD screen.
    • Remove the other small tab attached to the LCD screen.
  6. Canon PowerShot SX280 HS LCD Screen Replacement: étape 6, image 1 de 1
    • When removing the plastic casting, do not pull it all the way off. Detach the small tab first and make sure nothing else is attached to the casing.
  7. Canon PowerShot SX280 HS LCD Screen Replacement: étape 7, image 1 de 1
    • To remove the tabs from the camera, remove all screws.
    • Slowly lift the screen out of the camera using the tabs.
  8. Canon PowerShot SX280 HS LCD Screen Replacement: étape 8, image 1 de 1
    • Use the tabs, outlined in red, to slowly remove the LCD screen.
    • Remove the screws to remove the camera motherboard.
  9. Canon PowerShot SX280 HS LCD Screen Replacement: étape 9, image 1 de 1
    • Insert the replacement LCD screen.
    • Ensure that the long strip is attached to the original position.
  10. Canon PowerShot SX280 HS LCD Screen Replacement: étape 10, image 1 de 1
    • To reassemble your device, follow Steps 2 to 9 in reverse order.
Ligne d'arrivée
Osmand A Munoz
Membre depuis le 03/23/15
228 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team 1-5, Miles Spring 2015 Membre de l'équipe UMass Dartmouth, Team 1-5, Miles Spring 2015
UMASSD-MILES-S15S1G5
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 25
Total : 2,226
