Aller au contenu principal
Canon PowerShot SX50 HS Rear Case Replacement
Ce dont vous avez besoin
  1. Canon PowerShot SX50 HS Rear Case Replacement, Battery: étape 1, image 1 de 1
    • Locate the battery compartment on the bottom of the camera.
    • Push the latch on the outside of the battery door to the right to get to the battery pack inside.
  2. Canon PowerShot SX50 HS Rear Case Replacement: étape 2, image 1 de 1
    • Pull the brown latch on the inside of the battery door towards your palm (to the left). The battery pack should pop out (battery not pictured).
    • Now remove the battery pack from the camera with your fingers.
  3. Canon PowerShot SX50 HS Rear Case Replacement, Rear Case: étape 3, image 1 de 2 Canon PowerShot SX50 HS Rear Case Replacement, Rear Case: étape 3, image 2 de 2
    • Remove the two Phillips #000 screws, length 5 mm, on either side of the viewfinder.
    • Remove the one Phillips #000 screw, length 4 mm, on the bottom, closer to the back side of the camera.
  4. Canon PowerShot SX50 HS Rear Case Replacement: étape 4, image 1 de 2 Canon PowerShot SX50 HS Rear Case Replacement: étape 4, image 2 de 2
    • Remove the two Phillips #000 screws, length 3 mm, on the left side of camera.
    • Remove the Phillips #000 screw, length 4 mm, located between the two 3 mm screws.
    • Remove the two Phillips #000 screws, length 4 mm, on the bottom left corner of the camera.
  5. Canon PowerShot SX50 HS Rear Case Replacement: étape 5, image 1 de 1
    • Find the "A/V Out Digital" charging station and lift up the flap.
    • Remove the two Phillips #000 screws, length 5 mm, that are under the "A/V Out Digital" flap.
    • Remove the one Phillips #000 screw, length 5 mm, that is outside the "A/V Out Digital" flap.
  6. Canon PowerShot SX50 HS Rear Case Replacement: étape 6, image 1 de 2 Canon PowerShot SX50 HS Rear Case Replacement: étape 6, image 2 de 2
    • Use the plastic opening tool to carefully start lifting up the camera's left-side panel. Then use your fingers to pry off the rest.
  7. Canon PowerShot SX50 HS Rear Case Replacement: étape 7, image 1 de 3 Canon PowerShot SX50 HS Rear Case Replacement: étape 7, image 2 de 3 Canon PowerShot SX50 HS Rear Case Replacement: étape 7, image 3 de 3
    • Make sure the LCD screen panel, the battery compartment door, and the 'A/V Out Digital" flap are all open.
    • Using your fingers, carefully pry off the back encasement (you may need to use a plastic opening tool to help you).
    • Do not remove the back casing too far or too quickly. There is a wire ribbon attaching the back encasement to the motherboard that is very delicate.
  8. Canon PowerShot SX50 HS Rear Case Replacement: étape 8, image 1 de 3 Canon PowerShot SX50 HS Rear Case Replacement: étape 8, image 2 de 3 Canon PowerShot SX50 HS Rear Case Replacement: étape 8, image 3 de 3
    • Find the orange wire ribbon attaching the back encasement to the I/O board in the lower right-hand corner of the camera (lens facing away).
    • Carefully lift up the brown clip holding the wire ribbon in place and pull the ribbon out of the clasp with your fingers or tweezers.
    • Be cautious when the removing the wire ribbon; it is very delicate.
  9. Canon PowerShot SX50 HS Rear Case Replacement: étape 9, image 1 de 1
    • Now you can completely separate the back encasement from the rest of the camera.
3 autres ont terminé cette réparation.
Daniel Gurrola
Membre depuis le 04/01/15
255 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 12-7, Lancaster Spring 2015 Membre de l'équipe Cal Poly, Team 12-7, Lancaster Spring 2015
CPSU-LANCASTER-S15S12G7
5 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 10
Total : 1,017
