Aller au contenu principal
Canon PowerShot SX520 HS Metal Plate Replacement
Ce dont vous avez besoin
  1. Canon PowerShot SX520 HS Metal Plate Replacement, Back Face: étape 1, image 1 de 3 Canon PowerShot SX520 HS Metal Plate Replacement, Back Face: étape 1, image 2 de 3 Canon PowerShot SX520 HS Metal Plate Replacement, Back Face: étape 1, image 3 de 3
    • Remove 2-3.4 mm screws that secure the back panel using a Phillips #000 screwdriver.
    • Remove 4-4 mm screws on the left and right sides of the camera using a Phillips #000 screwdriver.
  2. Canon PowerShot SX520 HS Metal Plate Replacement: étape 2, image 1 de 1
    • Remove 2-4 mm screws that secure the bottom of the camera using a Phillips #000 screwdriver.
  3. Canon PowerShot SX520 HS Metal Plate Replacement: étape 3, image 1 de 2 Canon PowerShot SX520 HS Metal Plate Replacement: étape 3, image 2 de 2
    • Pull back the rubber facing to access the A/V and HDMI output compartment.
    • Remove 1-3.4mm screw inside the compartment using a Phillips #000 screwdriver.
  4. Canon PowerShot SX520 HS Metal Plate Replacement: étape 4, image 1 de 1
    • Once all screws are removed, pull the back facing off with your fingers.
  5. Canon PowerShot SX520 HS Metal Plate Replacement, LCD Screen: étape 5, image 1 de 1
    • Remove 3-4.4 mm screws that secure the small metal plate using a Phillips #000 screwdriver.
  6. Canon PowerShot SX520 HS Metal Plate Replacement: étape 6, image 1 de 1
    • Carefully pop out the LCD screen with your fingers.
  7. Canon PowerShot SX520 HS Metal Plate Replacement, Metal Plate: étape 7, image 1 de 3 Canon PowerShot SX520 HS Metal Plate Replacement, Metal Plate: étape 7, image 2 de 3 Canon PowerShot SX520 HS Metal Plate Replacement, Metal Plate: étape 7, image 3 de 3
    • Remove 6-4.4 mm screws that secure the metal cover using a Phillips #000 screwdriver.
    • Remove 2-2.5 mm screws that secure the back panel using a Phillips #000 screwdriver.
    • After all 8 screws are removed, pull the metal plate out with your fingers.
Lisa Choe
Membre depuis le 09/22/15
460 Réputation
3 tutoriels rédigés
Équipe
Baylor, Team 4-4, Williams Fall 2015 Membre de l'équipe Baylor, Team 4-4, Williams Fall 2015
BU-WILLIAMS-F15S4G4
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 9
30 derniers jours : 9
Total : 277
