Introduction
The removal of the back panel is necessary for almost all of the repairs for the Canon PowerShot SX60 HS.
The back panel protects the internal components and sensitive electronics in the device from the elements and minor damages.
Ce dont vous avez besoin
Make sure to power off the device before completing any more steps.
Remove the battery by releasing the orange clip in the battery compartment.
Use the Phillips #00 screwdriver to remove the 4mm #00 screw located on the bottom left of the device.
Use the Phillips #00 screwdriver to remove the 5mm #00 screw located on the bottom center of the device.
Use the Phillips #00 screwdriver to remove the 7mm #00 screw on the right top corner of the camera, just above the media ports.
Use the Phillips #00 screwdriver to remove the two 5mm #00 screws located on the right side, under the media port dust cover.
