Aller au contenu principal
Canon PowerShot SX60 HS Flash Replacement
Ce dont vous avez besoin
  1. Canon PowerShot SX60 HS Flash Replacement, Back Panel: étape 1, image 1 de 1
    • Make sure to power off the device before completing any more steps.
    • Remove the battery by releasing the orange clip in the battery compartment.
  2. Canon PowerShot SX60 HS Flash Replacement: étape 2, image 1 de 2 Canon PowerShot SX60 HS Flash Replacement: étape 2, image 2 de 2
    • Remove the rubber eye piece by pulling it back.
    • Use the Phillips #00 screwdriver to remove the two 5mm #00 screws located on the side of the viewfinder.
  3. Canon PowerShot SX60 HS Flash Replacement: étape 3, image 1 de 2 Canon PowerShot SX60 HS Flash Replacement: étape 3, image 2 de 2
    • Use the Phillips #00 screwdriver to remove the 4mm #00 screw located on the bottom left of the device.
    • Use the Phillips #00 screwdriver to remove the 5mm #00 screw located on the bottom center of the device.
    • Use the Phillips #00 screwdriver to remove the 7mm #00 screw on the right top corner of the camera, just above the media ports.
    • Use the Phillips #00 screwdriver to remove the two 5mm #00 screws located on the right side, under the media port dust cover.
  4. Canon PowerShot SX60 HS Flash Replacement: étape 4, image 1 de 2 Canon PowerShot SX60 HS Flash Replacement: étape 4, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Ensure the LCD screen is swung fully to the left before taking off the back panel.
    • Use the iFixit opening tool to pry off the back panel.
    • Don't completely pull off the back panel because there is still a ribbon attached.
    • Use the black spudger to unclip the ribbon located behind the battery compartment. Then remove it using the nylon tipped tweezers.
    • Once the ribbon is unplugged, remove the back panel from the camera body.
  5. Canon PowerShot SX60 HS Flash Replacement, Front Panel: étape 5, image 1 de 2 Canon PowerShot SX60 HS Flash Replacement, Front Panel: étape 5, image 2 de 2
    • Remove the sunshade located on the front of the lens by twisting it 90 degrees in either direction, then pull straight off the lens.
  6. Canon PowerShot SX60 HS Flash Replacement: étape 6, image 1 de 3 Canon PowerShot SX60 HS Flash Replacement: étape 6, image 2 de 3 Canon PowerShot SX60 HS Flash Replacement: étape 6, image 3 de 3
    • Remove the 5mm Phillips #00 screw located on the left side below the microphone connection.
    • Remove the 4mm Phillips #00 screw located on the bottom left of the camera.
    • Remove the 5mm Phillips #00 screw located on the bottom center of the camera.
    • Pop open the flash and remove the 5mm Phillips #00 screw located under the flash.
  7. Canon PowerShot SX60 HS Flash Replacement: étape 7, image 1 de 1
    • Remove the front cover by pulling along the lens housing while holding the body of the camera.
  8. Canon PowerShot SX60 HS Flash Replacement, Viewfinder: étape 8, image 1 de 2 Canon PowerShot SX60 HS Flash Replacement, Viewfinder: étape 8, image 2 de 2
    • Use the Phillips #00 screwdriver to remove the two 2mm #00 silver screws located under the viewfinder.
    • Don't pull the viewfinder all the way out because there is still a wire ribbon attached.
    • Remove the plastic housing around the viewfinder by using a black spudger or opening tool to unclip the 3 plastic clips on the sides of the viewfinder.
  9. Canon PowerShot SX60 HS Flash Replacement: étape 9, image 1 de 2 Canon PowerShot SX60 HS Flash Replacement: étape 9, image 2 de 2
    • Unclip the ribbon from the ZIF connector on the viewfinder.
    • Pull out the viewfinder.
  10. Canon PowerShot SX60 HS Flash Replacement, Side Panel: étape 10, image 1 de 3 Canon PowerShot SX60 HS Flash Replacement, Side Panel: étape 10, image 2 de 3 Canon PowerShot SX60 HS Flash Replacement, Side Panel: étape 10, image 3 de 3
    J'achète
    • Remove the 4mm #00 Philips screw located on the top left corner beneath the front panel.
    • Remove the 5mm #00 Philips screw located on the top left corner beneath the front panel.
    • Remove the 5mm #00 Philips screw located on the top of the left side panel near the microphone connection.
    • Remove the 4mm #00 Philips screw located on the bottom left corner beneath the front panel.
    • Using a black spudger, unclip the orange wire ribbon on the lower left corner of the motherboard and then remove it using the nylon tipped tweezers.
    • The side panel is now free and can be removed by pulling the panel to the left.
  11. Canon PowerShot SX60 HS Flash Replacement, Top Cover: étape 11, image 1 de 1
    • Remove one silver 2mm #00 Philips screw on the front side located next the flash assembly.
  12. Canon PowerShot SX60 HS Flash Replacement: étape 12, image 1 de 3 Canon PowerShot SX60 HS Flash Replacement: étape 12, image 2 de 3 Canon PowerShot SX60 HS Flash Replacement: étape 12, image 3 de 3
    J'achète
    • Use the black spudger to unclip the ribbon on the top right corner and then remove it using the nylon tipped tweezers.
    • Remove one silver 2mm #00 Philips screw found underneath the ribbon.
    • Once the screw is removed, the top panel is completely detached from the device. To remove it, grab it by hand and gently pull it off the device.
  13. Canon PowerShot SX60 HS Flash Replacement, Flash: étape 13, image 1 de 1
    • Remove the four 2mm #00 Phillips head screws from the metal back plate.
    • Remove the 4mm #00 Phillips head screw from the top corner of the metal back plate.
  14. Canon PowerShot SX60 HS Flash Replacement: étape 14, image 1 de 3 Canon PowerShot SX60 HS Flash Replacement: étape 14, image 2 de 3 Canon PowerShot SX60 HS Flash Replacement: étape 14, image 3 de 3
    • Remove two silver 2mm #00 Phillips head screws located near the top of the back panel.
    • Remove the two silver 2mm #00 Phillips head screws on the top side.
    • Use the black spudger to unclip the ribbon on the top right corner and remove it.
  15. Canon PowerShot SX60 HS Flash Replacement: étape 15, image 1 de 1
    • Once the above steps are completed, gently pull the flash assembly from the device and snap out the capacitor located on the front side of the camera
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 26
Total : 761
