Aller au contenu principal
Canon PowerShot SX600 HS Flash Assembly Replacement
Ce dont vous avez besoin
  1. Canon PowerShot SX600 HS Flash Assembly Replacement, Battery: étape 1, image 1 de 1
    • To remove the battery, locate the battery cover on the bottom of the camera.
    • Using your thumb, press down on the cover and slide it outwards.
  2. Canon PowerShot SX600 HS Flash Assembly Replacement: étape 2, image 1 de 1
    • Depress the orange lever holding the battery in place to unlock it.
  3. Canon PowerShot SX600 HS Flash Assembly Replacement: étape 3, image 1 de 2 Canon PowerShot SX600 HS Flash Assembly Replacement: étape 3, image 2 de 2
    • Use your fingers to remove the battery.
    • Be sure to remember the alignment of the nodes for reassembly.
  4. Canon PowerShot SX600 HS Flash Assembly Replacement, Power and Shutter Buttons: étape 4, image 1 de 1
    • Use a #000 Phillips screwdriver to unscrew the four 4mm screws located on the sides of the camera (2 for each side).
  5. Canon PowerShot SX600 HS Flash Assembly Replacement: étape 5, image 1 de 1
    • Unscrew the four 2mm located on the bottom of the camera using a Phillips #000 screwdriver.
  6. Canon PowerShot SX600 HS Flash Assembly Replacement: étape 6, image 1 de 1
    • Use a plastic opening tool to loosen and remove both the front and back plates of the camera, as well as the two side pieces.
  7. Canon PowerShot SX600 HS Flash Assembly Replacement: étape 7, image 1 de 2 Canon PowerShot SX600 HS Flash Assembly Replacement: étape 7, image 2 de 2
    • Unscrew the three 2mm screws attaching the piece to the camera frame with a #000 Phillips screwdriver.
  8. Canon PowerShot SX600 HS Flash Assembly Replacement: étape 8, image 1 de 1
    • Use an opening tool to gently remove the power and shutter button assembly from the frame.
  9. Canon PowerShot SX600 HS Flash Assembly Replacement, Display Screen: étape 9, image 1 de 2 Canon PowerShot SX600 HS Flash Assembly Replacement, Display Screen: étape 9, image 2 de 2
    • Unscrew the 2mm screw connections of the main board protector from the camera frame using a #000 Phillips head screwdriver (2 on front, 1 on top)
  10. Canon PowerShot SX600 HS Flash Assembly Replacement: étape 10, image 1 de 1
    • Use a Phillips #000 screwdriver to unscrew the 4mm screw.
  11. Canon PowerShot SX600 HS Flash Assembly Replacement: étape 11, image 1 de 1
    Outil utilisé dans cette étape :
    • Use a pair of tweezers to remove the no-fuss connector from its holder.
  12. Canon PowerShot SX600 HS Flash Assembly Replacement: étape 12, image 1 de 1
    • Gently lift the protector from the frame.
  13. Canon PowerShot SX600 HS Flash Assembly Replacement: étape 13, image 1 de 1
    • Lift the LCD screen ZIF connector tab and remove the ribbon cable.
    • Detach the no-fuss connector.
    • Lift the screen from its holder.
  14. Canon PowerShot SX600 HS Flash Assembly Replacement, Flash Assembly: étape 14, image 1 de 1
    • Unplug the assembly from the main no-fuss connector.
  15. Canon PowerShot SX600 HS Flash Assembly Replacement: étape 15, image 1 de 1
    • Unplug the assembly from its flat-top connection.
  16. Canon PowerShot SX600 HS Flash Assembly Replacement: étape 16, image 1 de 1
    • Use a #000 Phillips screwdriver to remove the three 4mm screws that hold the assembly to the frame.
  17. Canon PowerShot SX600 HS Flash Assembly Replacement: étape 17, image 1 de 1
    • Gently lift the assembly out of its place.
Fix your Canon's flash in order to take bright, vibrant photographs.
2 autres ont terminé cette réparation.
Scott Childress
Membre depuis le 02/15/17
752 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team S6-G4, Lacy Spring 2017 Membre de l'équipe USF Tampa, Team S6-G4, Lacy Spring 2017
USFT-LACY-S17S6G4
3 membres
9 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 8
30 derniers jours : 14
Total : 1,021
