Aller au contenu principal
Canon Powershot A610 Camera Housing Replacement
Ce dont vous avez besoin
  1. Canon Powershot A610 Camera Housing Replacement, Batteries: étape 1, image 1 de 2 Canon Powershot A610 Camera Housing Replacement, Batteries: étape 1, image 2 de 2
    • Unlock the battery cover, while swinging the cover outward to open it.
  2. Canon Powershot A610 Camera Housing Replacement: étape 2, image 1 de 1
    • Turn the camera over and allow the batteries to fall out.
    • Close the battery cover.
  3. Canon Powershot A610 Camera Housing Replacement, Camera Housing: étape 3, image 1 de 3 Canon Powershot A610 Camera Housing Replacement, Camera Housing: étape 3, image 2 de 3 Canon Powershot A610 Camera Housing Replacement, Camera Housing: étape 3, image 3 de 3
    • Remove the three 3 mm screws that attach the side panel to the body of the camera.
    • Using your fingernails, pull the side panel outward to remove it.
    • Remove the two remaining 2 mm screws that attach to the frame of the camera.
  4. Canon Powershot A610 Camera Housing Replacement: étape 4, image 1 de 1
    • Remove the 3 mm screw that sits at the bottom of the camera, near the front side.
    • Remove the 4 mm screw that sits at the bottom of the camera, near the back side.
  5. Canon Powershot A610 Camera Housing Replacement: étape 5, image 1 de 1
    • Open the battery cover.
    • Remove the 5 mm screw that sits on the top of the battery slot.
    • Remove the three 6 mm screws that sit at the bottom of the battery slot.
  6. Canon Powershot A610 Camera Housing Replacement: étape 6, image 1 de 2 Canon Powershot A610 Camera Housing Replacement: étape 6, image 2 de 2
    • Open the digital A/V DC terminal cover.
    • Remove the three 4 mm screws.
    • Detach the digital A/V DC terminal.
    • When you reassemble the camera, leave the topmost screw out until after you put the top casing back.
  7. Canon Powershot A610 Camera Housing Replacement: étape 7, image 1 de 1
    • Grip the sides of the top cover and gently lift it until it detaches from the camera.
    • Do not completely remove the top cover; an orange ribbon cable still connects it to the camera.
  8. Canon Powershot A610 Camera Housing Replacement: étape 8, image 1 de 2 Canon Powershot A610 Camera Housing Replacement: étape 8, image 2 de 2
    • With the camera upside down, pull the side of the front case that is closest to you, in an outward movement.
    • Apply some force, but pull the front case gently to prevent damage.
  9. Canon Powershot A610 Camera Housing Replacement: étape 9, image 1 de 2 Canon Powershot A610 Camera Housing Replacement: étape 9, image 2 de 2
    • Open the memory card slot cover.
    • Remove the 3 mm screw that sits near the bottom of the case.
  10. Canon Powershot A610 Camera Housing Replacement: étape 10, image 1 de 3 Canon Powershot A610 Camera Housing Replacement: étape 10, image 2 de 3 Canon Powershot A610 Camera Housing Replacement: étape 10, image 3 de 3
    • Flip the LCD screen all the way open.
    • Grip both sides of top of the back case and gently pull it, in an outward movement, until the case detaches.
3 autres ont terminé cette réparation.
Matthew Ramirez
Membre depuis le 01/20/11
625 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 11-26, Maness Winter 2011 Membre de l'équipe Cal Poly, Team 11-26, Maness Winter 2011
CPSU-MANESS-W11S11G26
3 membres
9 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 17
30 derniers jours : 27
Total : 9,299
