Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Introduction
How to remove the front panel.
  1. Open the battery compartment and remove the batteries.
    • Open the battery compartment and remove the batteries.
    • Remove the two screws that are deep in the battery compartment with a Phillips #00 screwdriver.
  2. Open the CF compartment and remove the top screw with a Phillips #00 screwdriver. The panel that holds the shutter button and zoom will come off.
    • Open the CF compartment and remove the top screw with a Phillips #00 screwdriver.
    • The panel that holds the shutter button and zoom will come off.
    • Be careful! There are two small wires connecting the speaker to the body of the camera. These are very delicate so proceed with caution. Do not remove.
  3. Unscrew the three small screws on the bottom of the camera with a Phillips #00 screwdriver.
    • Unscrew the three small screws on the bottom of the camera with a Phillips #00 screwdriver.
    • Remove the wrist strap.
  4. Remove the screw in the CF compartment with a Phillips #00 screwdriver.
    • Remove the screw in the CF compartment with a Phillips #00 screwdriver.
  5. Open the rubber Digital AV Out compartment flap. Pry the battery with the IFIXIT opening tool. Carefully pull out the battery with two fingers.
    • Open the rubber Digital AV Out compartment flap.
    • Pry the battery with the IFIXIT opening tool.
    • Carefully pull out the battery with two fingers.
    • Remove the two screws that are now visible with a Phillips #00 screwdriver.
  6. Starting from the bottom, carefully pull the casing off. The casing will now pivot at the top.
    • Starting from the bottom, carefully pull the casing off.
    • The casing will now pivot at the top.
    • There are three catches that hold the back casing to the body.
    • You may have to pull with some force. The rear panel will make a snapping noise when it separates from the body.
  7. The interior of the camera should look like this.
    • The interior of the camera should look like this.
  8. Remove the two screws at the top of the battery compartment with a Phillips #00 screwdriver.
    • Remove the two screws at the top of the battery compartment with a Phillips #00 screwdriver.
  9. With your right thumb, pull back on the tab while using your left hand to pull the face of the camera away from the body. With your right thumb, pull back on the tab while using your left hand to pull the face of the camera away from the body.
    • With your right thumb, pull back on the tab while using your left hand to pull the face of the camera away from the body.
2 autre(s) ont terminé cette réparation.
Brian
Membre depuis le 26/01/2010
102 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 14-40, Regan Winter 2010 Membre de l'équipe Cal Poly, Team 14-40, Regan Winter 2010
CPSU-REGAN-W10S14G40
5 membres
15 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 4
Total : 4,140
