Aller au contenu principal
Canon Powershot A70 Viewfinder Replacement
Ce dont vous avez besoin
  1. Canon Powershot A70 Viewfinder Replacement, Shutter/Speaker Panel: étape 1, image 1 de 1
    • Open the battery compartment and remove the batteries.
    • Remove the two screws that are deep in the battery compartment with a Phillips #00 screwdriver.
  2. Canon Powershot A70 Viewfinder Replacement: étape 2, image 1 de 2 Canon Powershot A70 Viewfinder Replacement: étape 2, image 2 de 2
    • Open the CF compartment and remove the top screw with a Phillips #00 screwdriver.
    • The panel that holds the shutter button and zoom will come off.
    • Be careful! There are two small wires connecting the speaker to the body of the camera. These are very delicate so proceed with caution. Do not remove.
  3. Canon Powershot A70 Viewfinder Replacement, Rear Exterior Panel: étape 3, image 1 de 1
    • Unscrew the three small screws on the bottom of the camera with a Phillips #00 screwdriver.
    • Remove the wrist strap.
  4. Canon Powershot A70 Viewfinder Replacement: étape 4, image 1 de 1
    • Remove the screw in the CF compartment with a Phillips #00 screwdriver.
  5. Canon Powershot A70 Viewfinder Replacement: étape 5, image 1 de 3 Canon Powershot A70 Viewfinder Replacement: étape 5, image 2 de 3 Canon Powershot A70 Viewfinder Replacement: étape 5, image 3 de 3
    • Open the rubber Digital AV Out compartment flap.
    • Pry the battery with an opening tool.
    • Carefully pull out the battery with two fingers.
    • Remove the two screws that are now visible with a Phillips #00 screwdriver.
  6. Canon Powershot A70 Viewfinder Replacement: étape 6, image 1 de 2 Canon Powershot A70 Viewfinder Replacement: étape 6, image 2 de 2
    • Starting from the bottom, carefully pull the casing off.
    • The casing will now pivot at the top.
    • There are three catches that hold the back casing to the body.
    • You may have to pull with some force. The rear panel will make a snapping noise when it separates from the body.
  7. Canon Powershot A70 Viewfinder Replacement: étape 7, image 1 de 1
    • The interior of the camera should look like this.
  8. Canon Powershot A70 Viewfinder Replacement, Front Exterior Panel: étape 8, image 1 de 1
    • Remove the two screws at the top of the battery compartment with a Phillips #00 screwdriver.
  9. Canon Powershot A70 Viewfinder Replacement: étape 9, image 1 de 2 Canon Powershot A70 Viewfinder Replacement: étape 9, image 2 de 2
    • With your right thumb, pull back on the tab while using your left hand to pull the face of the camera away from the body.
  10. Canon Powershot A70 Viewfinder Replacement, Viewfinder: étape 10, image 1 de 1
    • After removing the front and rear panels, locate the viewfinder directly above the lens on top of the camera.
    • Three screws hold the viewfinder in place: two on the top and one on the lens side of the camera.
    • First, remove the screw in the bent corner of the viewfinder with a Phillips #00 screwdriver.
  11. Canon Powershot A70 Viewfinder Replacement: étape 11, image 1 de 1
    • Remove the second screw directly across from the bent corner.
    • It may be hidden in the space under the orange circuitry with a Phillips #00 screwdriver.
  12. Canon Powershot A70 Viewfinder Replacement: étape 12, image 1 de 1
    • Remove the final screw directly under the left side of the viewfinder (on the lens side) with a Phillips #00 screwdriver.
  13. Canon Powershot A70 Viewfinder Replacement: étape 13, image 1 de 1
    • After removing the three screws, the only thing still holding the viewfinder in place is a small plastic peg.
    • Remove the viewfinder with a firm pull directly upwards.
Logan
Membre depuis le 01/26/10
9 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 14-40, Regan Winter 2010 Membre de l'équipe Cal Poly, Team 14-40, Regan Winter 2010
CPSU-REGAN-W10S14G40
5 membres
15 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 23
Total : 6,949
