Aller au contenu principal
Canon Powershot ELPH 100 HS Battery Replacement
  1. Canon Powershot ELPH 100 HS Battery Replacement, Battery: étape 1, image 1 de 3 Canon Powershot ELPH 100 HS Battery Replacement, Battery: étape 1, image 2 de 3 Canon Powershot ELPH 100 HS Battery Replacement, Battery: étape 1, image 3 de 3
    • Locate the battery cover on the bottom of your camera.
    • Slide the tab to the right to open the battery cover.
  2. Canon Powershot ELPH 100 HS Battery Replacement: étape 2, image 1 de 2 Canon Powershot ELPH 100 HS Battery Replacement: étape 2, image 2 de 2
    • Flip the battery cover open.
    • Using your fingers, slide the battery out of the camera.
    • This was not the original battery that came the camera, so yours may look different.
Lillia
Membre depuis le 03/17/15
267 Réputation
2 tutoriels rédigés
Équipe
Michigan Tech, Team 1-10, Lauer Spring 2015 Membre de l'équipe Michigan Tech, Team 1-10, Lauer Spring 2015
MTU-LAUER-S15S1G10
2 membres
5 tutoriels rédigés
3 commentaires
What if the internal time/date battery is bad? A fully charged battery will drain crazy fast because the rechargeable internal No longer charges. Is there a fix?
S Silvia - Réponse
Hi @ssilvia, there isn't a guide specifically for the CMOS or coin cell battery replacement but the Canon Powershot ELPH 100 HS Outer Case Replacement guide has an image that confirms there is a coin cell battery. It looks like you should be able to access and replace it. The photo is a little blurry so I couldn't read the specific size. I hope this helps or at least this might get you started on the repair. Thanks!
Sarah Westberg -
What if the battery cover (gray tab) is broken?? I accidentally ripped it off.
Jade - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 7
30 derniers jours : 32
Total : 1,991
