Aller au contenu principal
Canon Powershot ELPH 100 HS Memory Card Replacement
  1. Canon Powershot ELPH 100 HS Memory Card Replacement, Battery: étape 1, image 1 de 3 Canon Powershot ELPH 100 HS Memory Card Replacement, Battery: étape 1, image 2 de 3 Canon Powershot ELPH 100 HS Memory Card Replacement, Battery: étape 1, image 3 de 3
    • Locate the battery cover on the bottom of your camera.
    • Slide the tab to the right to open the battery cover.
  2. Canon Powershot ELPH 100 HS Memory Card Replacement: étape 2, image 1 de 2 Canon Powershot ELPH 100 HS Memory Card Replacement: étape 2, image 2 de 2
    • Flip the battery cover open.
    • Using your fingers, slide the battery out of the camera.
    • This was not the original battery that came the camera, so yours may look different.
  3. Canon Powershot ELPH 100 HS Memory Card Replacement, Memory Card: étape 3, image 1 de 3 Canon Powershot ELPH 100 HS Memory Card Replacement, Memory Card: étape 3, image 2 de 3 Canon Powershot ELPH 100 HS Memory Card Replacement, Memory Card: étape 3, image 3 de 3
    • Push down on the memory card until it clicks and releases.
    • Pull up on the memory card to remove it.
Lillia
Membre depuis le 03/17/15
255 Réputation
2 tutoriels rédigés
Équipe
Michigan Tech, Team 1-10, Lauer Spring 2015 Membre de l'équipe Michigan Tech, Team 1-10, Lauer Spring 2015
MTU-LAUER-S15S1G10
2 membres
5 tutoriels rédigés
Un commentaire
my internal card reader hardware is not functional
can i replace it somehow
s l - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 11
30 derniers jours : 37
Total : 1,028
