Aller au contenu principal
Pièces
Aucune pièce spécifiée.
  1. Remove the 2 screws (2.41 mm long) on the side of the camera next to the LCD screen. Remove the 2 screws (4.08 mm) on the other side.  One is located under the rubber USB flap. Remove the last screw (2.59 mm) located on the bottom of the camera.
    • Remove the 2 screws (2.41 mm long) on the side of the camera next to the LCD screen.
    • Remove the 2 screws (4.08 mm) on the other side. One is located under the rubber USB flap.
    • Remove the last screw (2.59 mm) located on the bottom of the camera.
    • Slowly pull the back cover of the camera.
  2. Unplug the green and white plugs connecting the top panel to the top of the logic board. Dislodge the tab above the lens.
    • Unplug the green and white plugs connecting the top panel to the top of the logic board.
    • Dislodge the tab above the lens.
    • Dislodge the back tab.
Robert Manno
Membre depuis le 05/01/2011
432 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 13-3, Forte Winter 2011 Membre de l'équipe Cal Poly, Team 13-3, Forte Winter 2011
CPSU-FORTE-W11S13G3
5 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 951
