Aller au contenu principal
Canon Powershot SX30 IS Back Camera Housing Replacement
Ce dont vous avez besoin
  1. Canon Powershot SX30 IS Back Camera Housing Replacement, Back Camera Housing: étape 1, image 1 de 2 Canon Powershot SX30 IS Back Camera Housing Replacement, Back Camera Housing: étape 1, image 2 de 2
    • Position the camera so that the right side is visible as shown.
    • Unscrew the two 6 mm screws shown using a screwdriver.
  2. Canon Powershot SX30 IS Back Camera Housing Replacement: étape 2, image 1 de 3 Canon Powershot SX30 IS Back Camera Housing Replacement: étape 2, image 2 de 3 Canon Powershot SX30 IS Back Camera Housing Replacement: étape 2, image 3 de 3
    • Remove the plastic flap by pressing down on the center of the hinge and pulling on the flap with the spudger.
    • Then, unscrew the lone 6mm screw that was under the plastic flap.
  3. Canon Powershot SX30 IS Back Camera Housing Replacement: étape 3, image 1 de 2 Canon Powershot SX30 IS Back Camera Housing Replacement: étape 3, image 2 de 2
    • Turn the camera so that the bottom is visible, as shown.
    • Unscrew the three 4mm screws shown red using a screwdriver.
    • Unscrew the single 6mm screw.
    • Do not touch the screw shown yellow, removal is unnecessary. (Note: the top right yellow screw should be removed)
  4. Canon Powershot SX30 IS Back Camera Housing Replacement: étape 4, image 1 de 1
    • Turn the camera so the back side is visible, as shown.
    • Unscrew the two 6mm screws.
  5. Canon Powershot SX30 IS Back Camera Housing Replacement: étape 5, image 1 de 1
    • Gently remove the back cover using the spudger.
    • Exercise caution, as the wire inside is fragile.
  6. Canon Powershot SX30 IS Back Camera Housing Replacement: étape 6, image 1 de 2 Canon Powershot SX30 IS Back Camera Housing Replacement: étape 6, image 2 de 2
    • Detach the wire by lifting the small black bar that holds it to the main body of the camera.
  7. Canon Powershot SX30 IS Back Camera Housing Replacement: étape 7, image 1 de 1
    • Attach the new cover onto the camera.
  8. Canon Powershot SX30 IS Back Camera Housing Replacement: étape 8, image 1 de 1
    • Reattach the wire to your new rear casing.
  9. Canon Powershot SX30 IS Back Camera Housing Replacement: étape 9, image 1 de 1
    • Close the back cover, and re-insert appropriate screws.
2 autres ont terminé cette réparation.
Ellis DeVoe
Membre depuis le 04/14/15
580 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 5-12, Maness Spring 2015 Membre de l'équipe Cal Poly, Team 5-12, Maness Spring 2015
CPSU-MANESS-S15S5G12
4 membres
5 tutoriels rédigés
Un commentaire
yellow marked screw must come out to remove cover next to battery door
begleylr - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 5
30 derniers jours : 11
Total : 1,468
