Aller au contenu principal
Canon Powershot SX30 IS Battery/SD Card Door Replacement
Ce dont vous avez besoin
  1. Canon Powershot SX30 IS Battery/SD Card Door Replacement, Battery/SD Card Door: étape 1, image 1 de 1
    • Open the protective door on the bottom of the camera, and remove the SD card and battery from the camera
  2. Canon Powershot SX30 IS Battery/SD Card Door Replacement: étape 2, image 1 de 2 Canon Powershot SX30 IS Battery/SD Card Door Replacement: étape 2, image 2 de 2
    • Unscrew the two 2mm screws from the inside of the case
  3. Canon Powershot SX30 IS Battery/SD Card Door Replacement: étape 3, image 1 de 2 Canon Powershot SX30 IS Battery/SD Card Door Replacement: étape 3, image 2 de 2
    • Remove the plastic backing and the metal front plate from the spring controlled hinge
    • To replace, hold the plastic backing to the metal hinge and screw the plate onto the front of it
That's It! Good Job!
Ellis DeVoe
Membre depuis le 04/14/15
580 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 5-12, Maness Spring 2015 Membre de l'équipe Cal Poly, Team 5-12, Maness Spring 2015
CPSU-MANESS-S15S5G12
4 membres
5 tutoriels rédigés
Un commentaire
What if the existing hinge is broken.....I need to replace the entire door and spring loaded hinge. Ya got instructions for that?
jusanotherhuman - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 8
30 derniers jours : 12
Total : 718
