Aller au contenu principal
Canon Powershot SX30 IS LCD Panel Rear Cover Replacement
Ce dont vous avez besoin
  1. Canon Powershot SX30 IS LCD Panel Rear Cover Replacement, LCD Panel Rear Cover: étape 1, image 1 de 1
    • Turn the camera so the back of it is facing you.
    • Pull the LCD screen towards you in order to open it,
  2. Canon Powershot SX30 IS LCD Panel Rear Cover Replacement: étape 2, image 1 de 2 Canon Powershot SX30 IS LCD Panel Rear Cover Replacement: étape 2, image 2 de 2
    • Unscrew the two 3 mm screws shown on the left side of the LCD screen panel using a Phillips screwdriver.
  3. Canon Powershot SX30 IS LCD Panel Rear Cover Replacement: étape 3, image 1 de 3 Canon Powershot SX30 IS LCD Panel Rear Cover Replacement: étape 3, image 2 de 3 Canon Powershot SX30 IS LCD Panel Rear Cover Replacement: étape 3, image 3 de 3
    • Unscrew the two 3 mm screws shown on the right side of the LCD screen panel.
  4. Canon Powershot SX30 IS LCD Panel Rear Cover Replacement: étape 4, image 1 de 2 Canon Powershot SX30 IS LCD Panel Rear Cover Replacement: étape 4, image 2 de 2
    • Using the plastic opening tool, remove the rear case of the front LCD cover.
  5. Canon Powershot SX30 IS LCD Panel Rear Cover Replacement: étape 5, image 1 de 1
    • Pull off the back panel of the LCD screen and the plastic wire protector. Then replace the back panel.
Ellis DeVoe
Membre depuis le 04/14/15
580 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 5-12, Maness Spring 2015 Membre de l'équipe Cal Poly, Team 5-12, Maness Spring 2015
CPSU-MANESS-S15S5G12
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 8
30 derniers jours : 18
Total : 341
