Aller au contenu principal
Canon Powershot SX500 IS Control Dial Replacement
Ce dont vous avez besoin
  1. Canon Powershot SX500 IS Control Dial Replacement, Battery: étape 1, image 1 de 1
    • Rotate the camera to expose the underside of the camera.
  2. Canon Powershot SX500 IS Control Dial Replacement: étape 2, image 1 de 1
    • Slide the rounded rectangle tab to the left to release the battery cover.
  3. Canon Powershot SX500 IS Control Dial Replacement: étape 3, image 1 de 1
    • Push the small orange tab forward to release the battery (Battery is ready for removal).
  4. Canon Powershot SX500 IS Control Dial Replacement, Back Cover: étape 4, image 1 de 3 Canon Powershot SX500 IS Control Dial Replacement, Back Cover: étape 4, image 2 de 3 Canon Powershot SX500 IS Control Dial Replacement, Back Cover: étape 4, image 3 de 3
    • Using the Phillips 00 screwdriver, remove the two 4mm top screws above the LCD screen.
  5. Canon Powershot SX500 IS Control Dial Replacement: étape 5, image 1 de 1
    • Using the Phillips 00 screwdriver, remove the two 4mm side screws to the left of the LCD screen.
  6. Canon Powershot SX500 IS Control Dial Replacement: étape 6, image 1 de 1
  7. Canon Powershot SX500 IS Control Dial Replacement: étape 7, image 1 de 1
    • Using the Phillips 00 screwdriver, remove the three 4mm screws from the underside of the camera.
  8. Canon Powershot SX500 IS Control Dial Replacement: étape 8, image 1 de 2 Canon Powershot SX500 IS Control Dial Replacement: étape 8, image 2 de 2
    • Using the plastic pry tool, remove the back cover from camera.
  9. Canon Powershot SX500 IS Control Dial Replacement, Control Dial: étape 9, image 1 de 1
    • Using the Phillips 00 screwdriver, remove the two 3mm screws closest to the right of the LCD screen.
  10. Canon Powershot SX500 IS Control Dial Replacement: étape 10, image 1 de 1
    • Using the Phiillips 00 screwdriver, remove the 4mm screw to the right of the control dial.
  11. Canon Powershot SX500 IS Control Dial Replacement: étape 11, image 1 de 1
    • Using the spudger, lift the control dial to the right of the LCD screen.
  12. Canon Powershot SX500 IS Control Dial Replacement: étape 12, image 1 de 1
    • Using the spudger, lift the connection tab and remove the control dial's orange ribbon from motherboard.
Shelby Spiering
Membre depuis le 04/07/15
252 Réputation
1 tutoriel rédigé
Un commentaire
Gracias gracias gracias
edgarlugo20111917 - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 11
Total : 470
