Aller au contenu principal
Canon Powershot SX500 IS Motherboard Replacement
Ce dont vous avez besoin
  1. Canon Powershot SX500 IS Motherboard Replacement, Battery: étape 1, image 1 de 1
    • Rotate the camera to expose the underside of the camera.
  2. Canon Powershot SX500 IS Motherboard Replacement: étape 2, image 1 de 1
    • Slide the rounded rectangle tab to the left to release the battery cover.
  3. Canon Powershot SX500 IS Motherboard Replacement: étape 3, image 1 de 1
    • Push the small orange tab forward to release the battery (Battery is ready for removal).
  4. Canon Powershot SX500 IS Motherboard Replacement, Back Cover: étape 4, image 1 de 3 Canon Powershot SX500 IS Motherboard Replacement, Back Cover: étape 4, image 2 de 3 Canon Powershot SX500 IS Motherboard Replacement, Back Cover: étape 4, image 3 de 3
    • Using the Phillips 00 screwdriver, remove the two 4mm top screws above the LCD screen.
  5. Canon Powershot SX500 IS Motherboard Replacement: étape 5, image 1 de 1
    • Using the Phillips 00 screwdriver, remove the two 4mm side screws to the left of the LCD screen.
  6. Canon Powershot SX500 IS Motherboard Replacement: étape 6, image 1 de 1
  7. Canon Powershot SX500 IS Motherboard Replacement: étape 7, image 1 de 1
    • Using the Phillips 00 screwdriver, remove the three 4mm screws from the underside of the camera.
  8. Canon Powershot SX500 IS Motherboard Replacement: étape 8, image 1 de 2 Canon Powershot SX500 IS Motherboard Replacement: étape 8, image 2 de 2
    • Using the plastic pry tool, remove the back cover from camera.
  9. Canon Powershot SX500 IS Motherboard Replacement, Control Dial: étape 9, image 1 de 1
    • Using the Phillips 00 screwdriver, remove the two 3mm screws closest to the right of the LCD screen.
  10. Canon Powershot SX500 IS Motherboard Replacement: étape 10, image 1 de 1
    • Using the Phiillips 00 screwdriver, remove the 4mm screw to the right of the control dial.
  11. Canon Powershot SX500 IS Motherboard Replacement: étape 11, image 1 de 1
    • Using the spudger, lift the control dial to the right of the LCD screen.
  12. Canon Powershot SX500 IS Motherboard Replacement: étape 12, image 1 de 1
    • Using the spudger, lift the connection tab and remove the control dial's orange ribbon from motherboard.
  13. Canon Powershot SX500 IS Motherboard Replacement, LCD Screen: étape 13, image 1 de 1
    • Using spudger, lift the tab on the connector and remove the orange ribbon from motherboard (LCD screen is separated from camera).
  14. Canon Powershot SX500 IS Motherboard Replacement, Lens: étape 14, image 1 de 1
    • Using the Phillips 00 screwdriver remove the seven 6mm screws from the housing plate of the LCD screen.
  15. Canon Powershot SX500 IS Motherboard Replacement: étape 15, image 1 de 1
    • Using the Phillips 00 screwdriver, remove the 4mm mounting screw from underneath the flash.
  16. Canon Powershot SX500 IS Motherboard Replacement: étape 16, image 1 de 1
    • Using the spudger, lift the flash unit away from the metal housing (Flash is lifted to allow more room for metal housing).
  17. Canon Powershot SX500 IS Motherboard Replacement: étape 17, image 1 de 1
    • Using the spudger, remove the metal housing (Metal housing is removed from camera).
  18. Canon Powershot SX500 IS Motherboard Replacement: étape 18, image 1 de 2 Canon Powershot SX500 IS Motherboard Replacement: étape 18, image 2 de 2
    • Using the spudger, lift the tab on the ZIF connector and remove both orange ribbons connected to the green motherboard (Motherboard is lifted from camera).
  19. Canon Powershot SX500 IS Motherboard Replacement: étape 19, image 1 de 1
    • Remove the lens from the lens shaft (Lens is removed from camera).
  20. Canon Powershot SX500 IS Motherboard Replacement, Motherboard: étape 20, image 1 de 2 Canon Powershot SX500 IS Motherboard Replacement, Motherboard: étape 20, image 2 de 2
    • Using the plastic pry tool, remove the motherboard and the flash unit from camera frame (Motherboard and flash unit are separated from camera).
  21. Canon Powershot SX500 IS Motherboard Replacement: étape 21, image 1 de 2 Canon Powershot SX500 IS Motherboard Replacement: étape 21, image 2 de 2
    • Using the Phillips 00 screwdriver, remove the 4mm screw from motherboard.
  22. Canon Powershot SX500 IS Motherboard Replacement: étape 22, image 1 de 3 Canon Powershot SX500 IS Motherboard Replacement: étape 22, image 2 de 3 Canon Powershot SX500 IS Motherboard Replacement: étape 22, image 3 de 3
    • Using the plastic opening tool, lift the tab on the connector and remove the two remaining orange ribbons from green motherboard (Motherboard is removed).
4 autres ont terminé cette réparation.
Jody Wilkerson
Membre depuis le 04/07/15
565 Réputation
4 tutoriels rédigés
Un commentaire
I can't download the pictures from the camera. It doesn't have the card you take out and download the pics. I would plug it in and download from camera to my desktop. It's now saying it can't connect to the camera. I bought a new cord but it's apparently the camera itself. Any way to download the pics I have on the camera?
lfj - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 19
Total : 825
