Aller au contenu principal
Canon SX40 HS camera Flash Cover Replacement
Ce dont vous avez besoin
  1. Canon SX40 HS camera Flash Cover Replacement, Flash Cover: étape 1, image 1 de 2 Canon SX40 HS camera Flash Cover Replacement, Flash Cover: étape 1, image 2 de 2
    • Extend the flash cover upwards and remove the 4 mm black screw located on the left side. You will need a Phillips #00 screwdriver to remove it.
    • Repeat to remove the 4 mm black screw located on the right side.
  2. Canon SX40 HS camera Flash Cover Replacement: étape 2, image 1 de 1
    • Remove the plastic cover using the iFixIt Plastic Opening Tool.
    • The plastic cover can only be removed in the down position.
  3. Canon SX40 HS camera Flash Cover Replacement: étape 3, image 1 de 2 Canon SX40 HS camera Flash Cover Replacement: étape 3, image 2 de 2
    • After removing the flash cover, remove the 6 mm silver screw on the right side with a Phillips #00 screwdriver.
    • Repeat to remove the 6 mm silver screw on the left side with a Phillips #00 screwdriver.
  4. Canon SX40 HS camera Flash Cover Replacement: étape 4, image 1 de 1
    • Replace the external flash cover or the internal flashlight when all 6 mm silver screws are out.
To reassemble your device, follow Steps 1-4 in reverse order.
John Bui
Membre depuis le 03/26/15
352 Réputation
3 tutoriels rédigés
Équipe
UMass Dartmouth, Team 7-7, Cichon Spring 2015 Membre de l'équipe UMass Dartmouth, Team 7-7, Cichon Spring 2015
UMASSD-CICHON-S15S7G7
3 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 12
30 derniers jours : 18
Total : 871
