Introduction
This guide will show you how to remove and replace the LCD display panel of the Vixia HF R62.
Ce dont vous avez besoin
Remove the strap by undoing the Velcro and pulling it through the thread points.
Remove the external battery pack by pressing down on the slide release and sliding it out.
Remove the two 3mm Phillips #000 screws.
Remove the 4mm Phillips #000 screw.
Using a spudger, disconnect the ribbon cable connector from the PC board shown in the picture.
Remove the 3mm Phillips #000 screw holding the display's ribbon wire to the casing.
