Introduction
Does your Capresso Infinity Coffee Grinder not turn on? Has the power cord started to fray? If so, there might be an issue with your power cord. Here is a guide to replace your Capresso Infinity power cord. All you need is a Torx Security T10 Bit Screwdriver and a 2.0 Flathead Screwdriver in order to remove the screws to replace the power cord.
Ce dont vous avez besoin
Twist the top plastic container to the left counterclockwise.
Pull upwards to remove.
Originally attached to the inside of the outer casing, the green wire needs to be fed through the zip tie which keeps it in place.
Lift up on the zip tie far enough to create a space to feed the green wire through.
Place the zip tie back around the column that you lifted it from.
All three wires that comprise the power cord should be detached from the coffee grinder.
