Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Capresso Infinity Timer/On Switch Replacement
Ce dont vous avez besoin
  1. Capresso Infinity Timer/On Switch Replacement, Metal Outside Casing: étape 1, image 1 de 2 Capresso Infinity Timer/On Switch Replacement, Metal Outside Casing: étape 1, image 2 de 2
    • Twist the top plastic container to the left counterclockwise.
    • Pull upwards to remove.
    Demander à FixBot
  2. Capresso Infinity Timer/On Switch Replacement: étape 2, image 1 de 3 Capresso Infinity Timer/On Switch Replacement: étape 2, image 2 de 3 Capresso Infinity Timer/On Switch Replacement: étape 2, image 3 de 3
    • Twist the top burr to the left counter clockwise.
    Demander à FixBot
  3. Capresso Infinity Timer/On Switch Replacement: étape 3, image 1 de 2 Capresso Infinity Timer/On Switch Replacement: étape 3, image 2 de 2
    • Flip entire device upside down.
    • Remove two rubber coverings on the back of the device.
    Demander à FixBot
  4. Capresso Infinity Timer/On Switch Replacement: étape 4, image 1 de 2 Capresso Infinity Timer/On Switch Replacement: étape 4, image 2 de 2
    • Remove four 11.59mm T10 screws.
    • The screws will have small circular washers under them. Put them aside for reassembly.
    Demander à FixBot
  5. Capresso Infinity Timer/On Switch Replacement: étape 5, image 1 de 3 Capresso Infinity Timer/On Switch Replacement: étape 5, image 2 de 3 Capresso Infinity Timer/On Switch Replacement: étape 5, image 3 de 3
    • Lift the metal outside casing off the black base.
    • Flip the outside casing forward so you have access to the inside of it.
    Demander à FixBot
  6. Capresso Infinity Timer/On Switch Replacement: étape 6, image 1 de 3 Capresso Infinity Timer/On Switch Replacement: étape 6, image 2 de 3 Capresso Infinity Timer/On Switch Replacement: étape 6, image 3 de 3
    • Remove one 11.59mm T10 screw.
    • Let the green wire fall, or place somewhere so it doesn't get in the way.
    • There will be a small metal retainer and washer, put them aside for reassembly.
    Demander à FixBot
  7. Capresso Infinity Timer/On Switch Replacement: étape 7, image 1 de 3 Capresso Infinity Timer/On Switch Replacement: étape 7, image 2 de 3 Capresso Infinity Timer/On Switch Replacement: étape 7, image 3 de 3
    • Remove two 11.59mm T10 screws.
    Demander à FixBot
  8. Capresso Infinity Timer/On Switch Replacement: étape 8, image 1 de 2 Capresso Infinity Timer/On Switch Replacement: étape 8, image 2 de 2
    • Remove the time/on switch by pulling upwards.
    Demander à FixBot
  9. Capresso Infinity Timer/On Switch Replacement, Timer/On Switch: étape 9, image 1 de 1
    • Strip the two wires of their black covering connecting them to the black box.
    Demander à FixBot
  10. Capresso Infinity Timer/On Switch Replacement: étape 10, image 1 de 3 Capresso Infinity Timer/On Switch Replacement: étape 10, image 2 de 3 Capresso Infinity Timer/On Switch Replacement: étape 10, image 3 de 3
    • Solder the two cords holding in the blue and white wire in the black timer box.
    Demander à FixBot
3 autres ont terminé cette réparation.
Melayne Spataro
Membre depuis le 10/09/18
272 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team S1-G1, Leahy Fall 2018 Membre de l'équipe USF Tampa, Team S1-G1, Leahy Fall 2018
USFT-LEAHY-F18S1G1
4 membres
10 tutoriels rédigés
7 commentaires de tutoriel
do you know where I can get a new black timer box?
geclay@hotmail.com - Réponse Partager
Where can I purchase a timer/on switch?
Rob Gordon - Réponse Partager
Same question here, where can I buy this part?
Dominic Daigle - Réponse Partager
Just piling on,has anyone found where to buy the Timer switch?
Chris DiNicolas - Réponse Partager
Same, looking for part number and/or where to buy the timer dial.
Hans Sorensen - Réponse Partager
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 6
30 derniers jours : 80
Total : 3,640
