Aller au contenu principal
Capresso Perfectea 260 Motherboard Replacement
Ce dont vous avez besoin
  1. Capresso Perfectea 260 Motherboard Replacement, Motherboard: étape 1, image 1 de 1
    • First, take the base of the device and flip it over.
  2. Capresso Perfectea 260 Motherboard Replacement: étape 2, image 1 de 2 Capresso Perfectea 260 Motherboard Replacement: étape 2, image 2 de 2
    • Remove the four 12 mm Phillips #2 screws surrounding the base then lift the bottom half of the base to expose the circuit boards inside the device.
  3. Capresso Perfectea 260 Motherboard Replacement: étape 3, image 1 de 1
    • Remove the two 7.5 mm Phillips #2 screws holding in the motherboard
  4. Capresso Perfectea 260 Motherboard Replacement: étape 4, image 1 de 1
    • Unplug the wire going into the side of the motherboard
  5. Capresso Perfectea 260 Motherboard Replacement: étape 5, image 1 de 2 Capresso Perfectea 260 Motherboard Replacement: étape 5, image 2 de 2
    • Use the metal spudger to cut open the rubber covering the latch where it clamps onto the copper tab.
    • Unplug wire at heating element by first using the metal spudger to push the latch in and then pushing it out.
    • Be careful when unplugging the wire as if it is done too forcefully it can damage the connection and make it difficult to connect a new motherboard
  6. Capresso Perfectea 260 Motherboard Replacement: étape 6, image 1 de 1
    • Lift the motherboard out of the device
Rohin Chander
Membre depuis le 04/14/15
101 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 6-17, Maness Spring 2015 Membre de l'équipe Cal Poly, Team 6-17, Maness Spring 2015
CPSU-MANESS-S15S6G17
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 2
Total : 228
