Introduction
If your car or truck won't start, it may be time to change the battery. A typical motor vehicle battery lasts about 3-4 years, but this lifespan can vary greatly depending on the conditions and your driving habits.
This guide uses a Toyota Corolla to demonstrate the procedure, which is similar to most common motor vehicles.
If you just need to temporarily disconnect the battery rather than remove or replace it, follow this shorter guide.
Warning: Modern vehicles with a start-stop system often have a battery management system (BMS) that makes it necessary to pair the battery with special equipment after a replacement. A disconnected battery can cause infotainment, powered windows, and other vehicle electronics to lose their settings and require re-initialization. In some cases, error codes must also be resolved. Consult your owner's manual for details.
Ce dont vous avez besoin
Make sure the transmission is in Park (or first gear if you have a manual gearbox) and that the parking brake is engaged.
In addition to being dirty, the battery contains corrosive agents and may release flammable gases.
Gloves can also help protect you from an unpleasant shock if you accidentally mishandle the battery.
If you're not sure, simply continue reading.
Pull the hood release lever. It's usually located inside the car, near the steering wheel.
Raise the hood by simultaneously lifting and pressing up on the hood latch release (usually located beneath the front edge of the hood, near the center or center-right).
Using a correctly sized wrench or socket, loosen the nut/bolt securing the cable on the negative battery terminal.
If the nut or bolt spins without loosening, it may be necessary to counter-hold the opposite side with a second wrench or socket.
Make sure to use a power/computer memory saver for newer car model before disconnecting the car battery. This should be done to prevent losing all your settings, radio stations etc.
Remove the insulating cover from the positive battery terminal (if one is present).
Remove the battery.
To prevent future corrosion, apply some vaseline to the terminals after the re-installation of the battery. The engine heat will help spread it into all the nooks & crannies that you think you might have missed.
21 autres ont terminé cette réparation.
3 commentaires
You should not just tell people to follow the directions in reverse order for reassembly. There are some steps most mechanics will want you to perform (e.g. applying a compound to the terminals to prevent corrosion) in addition to simply reattaching the cables.
As with most guides on iFixit, reassembly tips are included on the applicable step where appropriate.
good for car batery replacement
