Aller au contenu principal
Carburetor Cleaning
Ce dont vous avez besoin
  1. Carburetor Cleaning, Air Filter: étape 1, image 1 de 3 Carburetor Cleaning, Air Filter: étape 1, image 2 de 3 Carburetor Cleaning, Air Filter: étape 1, image 3 de 3
    • Before starting, ensure that the engine is not running and is not hot.
    • Pull the tab until the filter cover opens. Remove the filter cover.
    • Note that the bottom of the cover is hinged.
  2. Carburetor Cleaning: étape 2, image 1 de 1
    • Remove the air filter.
    • The air filter will be either an oily sponge, or an accordion-folded fabric.
    • Note that the air filter is saturated with oil. Wear gloves and use paper towels to avoid creating a mess.
  3. Carburetor Cleaning, Carburetor Cleaning: étape 3, image 1 de 3 Carburetor Cleaning, Carburetor Cleaning: étape 3, image 2 de 3 Carburetor Cleaning, Carburetor Cleaning: étape 3, image 3 de 3
    • Locate the four bolts holding the air filter housing to the engine. Remove these bolts using the ratchet driver and the appropriately sized socket.
    • Remove the 1/4" bolts.
    • Remove the 5/16" bolts.
  4. Carburetor Cleaning: étape 4, image 1 de 2 Carburetor Cleaning: étape 4, image 2 de 2
    • Lift away the air filter housing.
    • Note that the housing is still attached to the engine via a bendable plastic rod.
  5. Carburetor Cleaning: étape 5, image 1 de 1
    • Spray carburetor cleaner into the open carburetor.
    • You may want to wear gloves for this step, as carburetor cleaner is harmful if applied to the skin.
2 autres ont terminé cette réparation.
Ethan Narad
Membre depuis le 04/19/18
529 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team S25-G15, Maness Spring 2018 Membre de l'équipe Cal Poly, Team S25-G15, Maness Spring 2018
CPSU-MANESS-S18S25G15
4 membres
7 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 17
Total : 1,825
